horn wire peugeot 206 /2007
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=114628
Printed Date: April 02, 2026 at 3:07 AM
Topic: horn wire peugeot 206 /2007
Posted By: portos
Subject: horn wire peugeot 206 /2007
Date Posted: June 22, 2009 at 6:37 PM
Hi all.
I want to install the horn honk wire alarm cable to mi ca horn wire. Should I use the stering column wire cable or the fuse box horn cable?,and,,,sorry...but where is the horn cable in the fuse box, I dont want to check all the cables with the multimeter, I dont want to be a deaf person..
Thanks in advance
Posted By: i am an idiot
Date Posted: June 22, 2009 at 7:57 PM
If Howie can't help you, a set of ear muffs and a meter are in your near future.  I can find no info on that vehicle.  Hopefully he will see this when he awakes.
Posted By: howie ll
Date Posted: June 23, 2009 at 3:28 AM
All the wires around the steering column are data, don't bother.  Go to the engine bay fuse box*adjacent to battery, one of the plugs on top. One of these vertical wires will go neg on horn push, thus a negative feed to that wire will sound the horn.  *Horn relay is in that box. Don't ask me the colour, we've already stated why not on previous Peugeot posts. This is 05 onwards with the cobined lock/haz switch top dash although earlier models might be the same I can't guarantee it.
