optional sensor port 4 pin connector
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=114769
Printed Date: April 30, 2026 at 3:14 PM
Topic: optional sensor port 4 pin connector
Posted By: brandonbailey1
Subject: optional sensor port 4 pin connector
Date Posted: June 30, 2009 at 5:38 AM
Ive been out of the game for a while but the only 4 port left unused on my Viper 5901 is next to the H1 harness. I this the 4 port that I need to plug my glass breakage sensor into? If so where do I get the plug? Ok, so I made one...how about the pin configuration? Ive tried everything with no luck...do I need to wait for my Bitwriter?
I want to hook it up to Zone 4 Sensor 2 - Optional MUX sensor port.
Posted By: Mark Mizenko
Date Posted: June 30, 2009 at 12:54 PM
You mean the White port on the Ignition Wires Connector?
The same as an old DEI impact sensor.......
Closest to the Igniton wire connector   is  RED
Going towards the end of the case.... Black, then Blue, the Green
