what kind of lock system do i have?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=114807
Printed Date: April 30, 2026 at 9:02 AM
Topic: what kind of lock system do i have?
Posted By: stryped
Subject: what kind of lock system do i have?
Date Posted: July 02, 2009 at 7:46 AM
Can you tell me what kind of lock system is used on a 2000 Dodge Dakota with factory power door locks? I believe it has factory keyles entry too but not 100% sure on that.
Posted By: tommy...
Date Posted: July 02, 2009 at 8:55 AM
Power UnlockLIGHT GREEN(-)POWER MASTER SWITCH IN DRIVERS DOOR...
posted_imagePowerLockPINK(-)
POWER MASTER SWITCH IN DRIVERS DOOR...REQUIRES DOUBLE PUSLE
What are you doing...?Just adding keyless entry...? Most units are negative trigger(door locks)...So if you list the unit, we could probably give you specifics...Otherwise you are pretty much just taking wires from alarm/units lock/unlock directly to the door lock wires in the car...!
M.E.C.P & First-Class
Posted By: stryped
Date Posted: July 02, 2009 at 9:09 AM
I do appreciate any help. I have a 450 Python esp in the truck that apparently was installed at a local best buy (not by me) several years ago. The remote start was connected but the door lock/unlock was not. I would like to connect this feature.
I believe the python has a green wire that says (-) lock (+) unlock output
and a blue wire that says (-) unlock (+) lock output
Can anyone tell me what I need to connect these wires to in the 2000 Dakota? I dont quite understand what the (-) and (+) mean. I really appreciate your help. This think does not look like it was installed very well. The LED and vallet switch are just sort of hanging under the dash.
Posted By: stryped
Date Posted: July 02, 2009 at 10:45 AM
By the way, I was just on the Bulldog site and it said my truck was a Chrysler 3/5 wire system because it came factory with keyless entry I believe. How does that system work and is it more involved to install the doorlock function on my python 450 esp system?
Posted By: KarTuneMan
Date Posted: July 02, 2009 at 1:09 PM
With factory keyless your truck lock/unlock is negative pulse thru resistance.
Lock is thru 620 ohms, unlock is thru 1.5 kohms. Double pulse is required, 1st pulse is disarm, second will unlock!
