2007 350z neutral safety?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=115164
Printed Date: May 06, 2026 at 9:49 AM
Topic: 2007 350z neutral safety?
Posted By: hydrodancer91
Subject: 2007 350z neutral safety?
Date Posted: July 18, 2009 at 2:52 PM
does anyone know what color and where the neutral safety wire is on a 2007 nissan 350z with a manual transmission? thanks in advance.
steve
Posted By: KPierson
Date Posted: July 18, 2009 at 7:52 PM
Pin 109 at the ECU - brown in color. The service manual shows that it reads 12vdc when the tranny is in neutral and 0vdc when in any gear so you may need to reverse the logic of the signal (with a transistor, preferably). ------------- Kevin Pierson
Date Posted: July 18, 2009 at 8:07 PM
i did one of these awhile back and thought that i had found a wire that read ground when in neutral?
Posted By: KPierson
Date Posted: July 18, 2009 at 8:20 PM
I know the older ones did, I've never done an '07. It's always possible the FSM is wrong - I've found quite a few errors in Nissan manuals. ------------- Kevin Pierson
Posted By: KarTuneMan
Date Posted: July 19, 2009 at 7:34 AM
hydrodancer91 wrote:
does anyone know what color and where the neutral safety wire is on a 2007 nissan 350z with a manual transmission? thanks in advance. steve
Did you find your wire...? and did you get done with what you were trying to do? (what were you attempting?) -------------
Date Posted: July 19, 2009 at 9:04 AM
no i havent found the wire. its a friend of mine's car. he bought it with an alarm and remote start but since its a stick whoever installed it didnt hook up the neutral safety wire from the remote start so it will start in any gear. and he doesnt like that so im going to hook it up for him. i was pretty sure theres a wire that rest at ground when the car is in neutral that i can use but if not and its only the brown wire i was told about then i can just use a relay i suppose to switch that wire to negative for the alarm.
Posted By: flobee4
Date Posted: July 19, 2009 at 9:49 AM
How about using the positive brake shutdown wire instead of the negative hood shutdown. Just make sure you Diode isolate the Neutral Saftey wire from the Brake Wire, this way when you put your car in neutral the brake lights won't come on. Hooking it up this way will require no relay draining on your battery, just 2 diodes.
Posted By: KPierson
Date Posted: July 19, 2009 at 10:06 AM
If it does show 12vdc in N then the + brake shut down won't work. If you need to change the polarity and want to use a relay, at least use a reed relay - you don't want the relay to click every time the car is shifted in to N (which is why I recomended using a transistor). ------------- Kevin Pierson
Posted By: flobee4
Date Posted: July 19, 2009 at 10:20 AM
Your right, I was thinking of a suburu I had done like that. Different application. It wil not work on this car, I should have read KPierson's description of the Neutral Saftey wire better. Use a relay or as he recommended a transistor.
Date Posted: July 19, 2009 at 11:10 AM
ive never used a transistor in this way could you explain please?
Posted By: KPierson
Date Posted: July 19, 2009 at 2:27 PM
If you use a general purpose transistor (like a 2n2904) you would wire the base to the P/NP wire (brown wire in car) the emitter to ground and the collector to the alarm. You should incorporate a few resistors to protect the transistor - a 470 ohm resistor between the P/NP signal wire and the base should work, and then a 100 ohm resistor between the collector and the alarm. This will convert the polarity without making any noise. ------------- Kevin Pierson
Date Posted: July 19, 2009 at 3:23 PM
that part number you had on there. where do i get that? is that a radio shack number?
Posted By: KPierson
Date Posted: July 19, 2009 at 3:57 PM
It isn't a Radioshack number, but they should have the 2n3904 transistor. Any general purpose NPN transistor will work.
Date Posted: July 20, 2009 at 1:06 PM
Have we found out what he is installing yet? This is why I ask: Any post containing any information that may be considered a violation of law or lead to an unlawful act in the United States of America such as injuring or killing someone or aiding in theft may be deleted and your membership may be suspended without notice. This includes bypassing head unit lockout codes, video bypass procedures, automatic transmission remote start units in manual transmission vehicles, etc. -------------
Date Posted: July 20, 2009 at 3:18 PM
Well here's what's up he's got an alarm remote start combo that was previously installed its one that can be used on a manual ot has the safety wire that has to show ground in ordere to remote start, so my plan is to connect this to the neutral safety wire like I've done several times before so the car won't start unless its in neutral. Unfortunetaly I haven't done one on a 350z for quite awhile so I figured someone on here would know off the top of their head. So to answer your accusation no I'm not trying to do what youtr thinking I've been in this industry for 15 years I now how it works. But I'm trying to fix it so my customers car quits lunging and won't start in gear like it does now.
Date Posted: July 20, 2009 at 3:21 PM
Sorry for the typos typing on a phones keyboard sucks
Posted By: KPierson
Date Posted: July 29, 2009 at 9:17 PM
Is it really an issue to install a "automatic" remote start system in a manual vehicle IF the vehicle has a sufficient OEM neutral safety wire? I realize the danger (and liability) of installing a system with no safeties or even homemade safeties, but when an OEM safety is incorporated I personally don't see an issue with it. If it is against the site rules please feel free to delete my posts on the topic!
