97 chevy k1500 astra 1000rs window prob.
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=115198
Printed Date: May 06, 2026 at 7:35 PM
Topic: 97 chevy k1500 astra 1000rs window prob.
Posted By: redhondapimp
Subject: 97 chevy k1500 astra 1000rs window prob.
Date Posted: July 20, 2009 at 5:41 PM
Hey all- I just installed an Astra 1000RS on my 97 Chevy k1500. That all went in without a problem. I used to diagram from here. I have an extra channel which I want to use to roll my windows down. The channel out is -500ma. I used a relay to swap the polarity to positive and I hooked it up to the Brown and Tan as described in the diagram. I can hear the relay in the astra clicking but the windows dont move. I used my volt tester on it and these wires had power flowing through them in both directions; up and down. I am kinda stumped now. If anyone has any ideas I would def appreciate it! Thanks!
Posted By: i am an idiot
Date Posted: July 21, 2009 at 10:56 PM
I am assuming that the K1500 is the full size van. This is the info from this site for the van, the wires you listed are for window down. I have no idea if these are the actual motor wires or the wires that trigger the relays to move the windows. Can you tell me if these wires go to the motor? | Windows Up | LF=Dark Blue, RF=Light Blue | | Windows Down | LF=Dark Brown, RF=Tan |
You may have to do a little footwork with a meter so we can determine what kind of system we are dealing with, but we should be able to get it to work. ------------- Let's Go Brandon Brown. Congratulations on your first Xfinity Series Win. LGBFJB
Date Posted: July 22, 2009 at 7:49 PM
Hey there, I those colors, its on a k1500 pickup. I tapped into those colors right by the remote, and i get nothing but a popped fuse. from there i went into the actual motor. i volted it out and found which one had juice going down and tapped into that. I still get a popped fuse when the relay kicks on. one time the window did move, but like 1/2 a millimeter. here is what i have going on: 86: -500ma from brain 87/85: 12v 30: out to motor
Date Posted: July 22, 2009 at 8:25 PM
What kind of voltage do you get on the 2 wires that go to the motor. Not pressing any buttons. Just what is the voltage on both wires? Black lead on ground, red lead to one wire, then move red lead to the other wire. Are you familiar with 5 wire door lock setups?
Date Posted: July 23, 2009 at 9:00 PM
I am not familiar with 5 wire door lock setup, but when you said that it dawned on me to look into that. I thought thats what its was! i rushed out and bought new fuses, but....same thing it pops the fuse. This is really starting to get on my nerves!! arg!! I volted out the 2 wires straight to the motor at a stand still. I did it both ways and still pulled up no juice. I looked up the 5 wire door lock on here and tried it...nothing...im thinking this can't be that difficult!! as of now ive blown through atleast 14 fuses and 9 advil! haha! do you have any ideas of where to go from here??
Date Posted: July 26, 2009 at 9:41 AM
I guess I am supposed to assume this means there was a voltage reading of 0.00 on your meter when you checked voltage on both wires. This time set your meter to the Ohms selection, and do the same thing again. Black lead on ground, red lead to each of the 2 motor wires. Give me the meter reading of each wire. When you tried the 5 wire setup, did you cut the motor wires?
Date Posted: July 26, 2009 at 11:35 AM
Well what happend with the motor wires, when it went up the blue had 11.3 volts, when it was going down the brown had 11.3 volts. When there was nothing it was at 0 volts. I ohmed out both driver and passenger side, both at 200. The driver side had .8 and the passenger side was at .3. Thats the diagram I was using, but everytime i would hook up the constant 12 volt It would pop the fuse. I thought I should be using a different diagram cause that setup was calling for 2 neg inputs (1 for lock/1 for unlock). It just seems that everytime it has the 12 volt constant going into the switch it will pop the fuse. I am just lost on this!! i really appreciate the help your giving me!
