Audiovox 9903 Wiring Diagram
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=115271
Printed Date: May 07, 2026 at 4:54 PM
Topic: Audiovox 9903 Wiring Diagram
Posted By: rebelmhz
Subject: Audiovox 9903 Wiring Diagram
Date Posted: July 24, 2009 at 3:51 PM
I'm looking for the wiring diagram for the Audiovox AS9903 auto alarm.
I have a 2000 Mitsubishi Eclipse that has this after market alarm system in it. A few days ago, either the remote stopped working, or the receiver module for the unit stopped working.
Either way, I can't get the engine to even attempt to start. I would like to completely remove the system and install a new alarm system. Any help would be greatly appriciated.
Regards,
rebelmhz
See You In CyberSpace...!!!
Posted By: Chris Luongo
Date Posted: July 25, 2009 at 5:55 PM
AS9903 is only the part number for the siren.
If you can get some of the numbers (or better, a picture) from the main brain under the dash, that would be of more help.
You should be able to turn the alarm off, so you can start the car, by turning the ignition on, and then pressing and releasing the valet button once.
If it's an older system, the valet switch is a toggle instead of a pushbutton. In that case, turn the ignition on, then move the valet switch to the "on" position.
Posted By: rebelmhz
Date Posted: July 26, 2009 at 6:44 PM
Ok, I will check it out and see if I can find the button or switch under the dash, I'll also try and find the model # of the unit.
Thanks.
rebelmhz
