2009 toyota corolla add on starter
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=115355
Printed Date: April 11, 2026 at 4:55 AM
Topic: 2009 toyota corolla add on starter
Posted By: miro2u
Subject: 2009 toyota corolla add on starter
Date Posted: July 29, 2009 at 7:07 PM
Need help finding wire that gives negative or positive output when lock button is pressed on factory remote. Add-on(mars 10) is installed and working if i manually give 4 ground impulses, only thing left is finding wire to hook up. Wire that triggers door lock wont work because its dead when remote button is pressed.Any suggestion is appreciated.
Thank You.
Posted By: i am an idiot
Date Posted: July 29, 2009 at 8:00 PM
If the car is running, does the keyless entry still operate the door locks?  If it does not, once you remote start the car, you will not be able to kill it with the remote.
Posted By: miro2u
Date Posted: July 29, 2009 at 8:45 PM
No remote does not work after car is running, I`m aware of that and its OK. Key will have to be used to enter vehicle and shut it down if needed.
Date Posted: July 29, 2009 at 9:13 PM
What color wire and what location did you try to use?   Audiovox has the following info for your vehicle.
posted_imagePowerLockPINK(-)DRIVERS KICK PANEL IN HARNESS FROM DRIVERS DOOR
Posted By: miro2u
Date Posted: July 29, 2009 at 9:20 PM
That is the one i was trying to use. If i use that one i can start vehicle pressing lock 4 times on the doors but not with remote.
Posted By: JWorm
Date Posted: July 29, 2009 at 9:48 PM
You want to use the wire listed as "lock motor" on most tech sheets. This wire will shows +12v when locking with the remote or switch on the door. According to the link below it is BROWN or ORANGE depending on the model of Corolla you have. You can find the wire in the drivers kick panel. You may need to use a relay to switch the polarity if your unit requires a (-) signal.
https://www.the12volt.com/installbay/forum_posts.asp~TID~102124
Posted By: howie ll
Date Posted: July 30, 2009 at 10:09 AM
Come to think of it you will need relay driven lock outputs from your unit, you have to open the lock wire. Also and I'm asking not telling, isn't there a key-sense wire one could use?
Posted By: miro2u
Date Posted: July 30, 2009 at 3:40 PM
I will try using "lock motor" wire trough relay to get negative.Let you know what happens. Thank you for suggestion.
Posted By: miro2u
Date Posted: July 30, 2009 at 3:48 PM
There is(blue @ignition switch), but how would i use keysense wire to neg. impulse? Or maybe i did not understand what you mean.
Posted By: Mike M2
Date Posted: July 31, 2009 at 6:32 AM
Listen to what Jworm has posted, it's the correct way to do this. The wire is in the harness coming in from the drivers door...
Mike M2
Tech Manager
CS Dealer Services
