2009 camry trunk release
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=115788
Printed Date: May 05, 2026 at 10:20 PM
Topic: 2009 camry trunk release
Posted By: opj38
Subject: 2009 camry trunk release
Date Posted: August 20, 2009 at 10:53 AM
I have installed a remote starter in car and it works perfect. The only problem I have is the Trunk Release. The remote has a Neg. pulse for the trunk. But the wiring info for the car says that the Polarity is REVERSE. How do I wire this neg output to a reverse polarity wire to pop the trunk, or is it possible?
Posted By: mikvot
Date Posted: August 20, 2009 at 2:12 PM
You need to get a SPDT relay. Find your trunk release wire of the vehicle, and cut it. You now have two pieces of wire, one side is the switch side, and the other is the motor side. If you get the trunk release wire down in the kick panel, once you cut it, the half that runs to the back of the car, will be the motor side.
Wire like this.
86 and 87 12volt
85 neg. trunk release wire from alarm
87a switch side of vehicles cut trunk release wire.
30 motor side of vehicles cut trunk release wire.
Posted By: opj38
Date Posted: August 20, 2009 at 3:30 PM
Thanks you very much, I will try that.
Posted By: i am an idiot
Date Posted: August 20, 2009 at 3:57 PM
I have no idea if the wire you need is WHITE/ Blue, but this is a picture of what Mikvot was describing. ------------- Let's Go Brandon Brown. Congratulations on your first Xfinity Series Win. LGBFJB
Posted By: howie ll
Date Posted: August 20, 2009 at 4:44 PM
Wasn't the SAME question answered 3 weeks ago? Lets have an FAQ section with the usual culprits, tach sensing by-pass integration, 1076 door pins etc.
Posted By: Velocity Motors
Date Posted: August 20, 2009 at 10:23 PM
Same old, same old. Questions asked 100's of times over years and years. Just easier to ask than to ------------- Jeff
Date Posted: August 20, 2009 at 10:34 PM
If you do a search for "Camry trunk release" you come up with 58 results. Who has time to go through all of those posts?
