2005 ford escape module
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=116664
Printed Date: April 09, 2026 at 5:40 PM
Topic: 2005 ford escape module
Posted By: suzuki7
Subject: 2005 ford escape module
Date Posted: October 02, 2009 at 12:26 PM
Hi, Does anyone know if the 555F or 555S will work on the Escape, I know they are a little older modules...Thanks.
The best way to predict the future is to create it!
Posted By: flobee4
Date Posted: October 02, 2009 at 10:22 PM
The 555F will not work on any year Escape and the 555S will only goto 2004. You will need the 556F for 2005 and up Escapes. You can also check out bypasskit.com, ifar.ca and idatalink.com for other solutions besides the 556F. the 556F uses a ring that needs to be positioned around the ignition cylinder, you need to find the "sweet" spot for it to work.. There are also "data" solutions available that require tapping into 2 data wires in the Escape and bypass the transponder. Very easy to do on Fords and more reliable in my opinon.
Frank
Posted By: pcr-63
Date Posted: October 03, 2009 at 10:03 PM
You can use the flcan it works well with that car. It is made by idatalink
www.flash-it.com
