python 872
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=116764
Printed Date: April 10, 2026 at 4:05 PM
Topic: python 872
Posted By: bennyhill007
Subject: python 872
Date Posted: October 06, 2009 at 8:17 PM
Would appreciate any trade install tips on a 96 Civic LX sedan.
Posted By: t&t tech
Date Posted: October 06, 2009 at 8:47 PM
What exactly are you looking for help with? Remote start assistance or just basic alarm!
Date Posted: October 06, 2009 at 11:09 PM
"the whole enchilada" Remote start + power locks + Power windows
Posted By: t&t tech
Date Posted: October 07, 2009 at 7:11 PM
> | 1996 Honda Civic Alarm, Remote Starter, Keyless Entry Wiring Information | | Constant 12V+ | White | Ignition Switch Harness | | Starter | BLACK/ White | Ignition Switch Harness | | Ignition | BLACK / YELLOW | Ignition Switch Harness | | Ignition 2 | Yellow | Ignition Switch Harness | | Accessory | WHITE/ Black | Ignition Switch Harness | | Tach | Blue | Coil | | Brake Switch | GREEN / WHITE | Brake Switch | | Trunk Pin | Blue/Black (-) | Driver's Kick or behind Radio Light Green (-) Wire | | Parking Lights | RED / Black | Driver's Kick Panel or above Fuse Panel | | Head Lamp | RED / White L | And RED / Blue R at Steering Column | | Door Trigger | Light GREEN/ Red (-) | Above Fuse Panel or behind Radio Green Connector | | Door Lock | GREEN / WHITE (-) | Driver's Kick Blue Connector or at Anti-Theft | | Door Unlock | GREEN/ Orange (-) | Module behind Radio Green Connector Negative Trigger | | Horn Wire | Gray (-) | Steering Column or Green Connector behind Radio |
Posted By: t&t tech
Date Posted: October 07, 2009 at 7:14 PM
That's the enchilada, half cooked! -------------
Date Posted: October 09, 2009 at 3:03 PM
What type of door lock systems does Civic uses? Type A? B? C? D? E? F? G? H?
Posted By: t&t tech
Date Posted: October 09, 2009 at 5:20 PM
Type B, or negative trigger!
Date Posted: October 25, 2009 at 6:57 PM
I want to only connect the starter kill and not the remote start. Which wires do I use on the H3 connector (9 pin)?
Posted By: t&t tech
Date Posted: October 25, 2009 at 7:00 PM
what wires do you have on that harness?
Date Posted: October 25, 2009 at 7:28 PM
1 PINK (+) IGNITION 1 INPUT/OUTPUT
2 RED / WHITE (30A) FUSED IGNITION 2 / FLEX RELAY INPUT 87
3 ORANGE ACCESSORY OUTPUT
4 VIOLET (+) STARTER OUTPUT (CAR SIDE OF THE STARTER KILL WIRE)
5 GREEN (+) STARTER INPUT (KEY SIDE OF THE STARTER KILL WIRE)
6 RED (+) FUSED (30A) IGNITION 1 INPUT
7 PINK/WHITE (+) IGNITION 2 / FLEX RELAY OUTPUT
8 PINK/BLACK FLEX RELAY INPUT 87A key side (if required) of FLEX RELAY
9 RED / BLACK FUSED (30A) ACCESSORY/STARTER INPUT
10 N/C N/C
Posted By: howie ll
Date Posted: October 26, 2009 at 2:49 AM
The Violet and the Green, also on a 96 you might need to install an actuator in the driver's door, but check and test from the above list. Honda window lift, go to the motor wires., especially on driver's side.
Posted By: t&t tech
Date Posted: October 26, 2009 at 4:00 PM
To add to howard, you would also connect the pink ignition wire, it is an input as well as an output!
Date Posted: October 26, 2009 at 6:06 PM
What would be an ideal mount location for the control module? I taken apart the dash as well as the center console and glove box. I did not see anywhere obvious where I can securely attache the control module. I mounted the 508D behine the parking brake handle.
Date Posted: October 27, 2009 at 11:32 PM
What did Howie meant when he said...."go to the motor wires., especially on driver's side" on October 26, 2009 at 2:49 AM. Would I not just ground the "Ground Output When Armed" aka orange wire?
