remote start, 03 ram 1500
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=116785
Printed Date: April 11, 2026 at 4:06 AM
Topic: remote start, 03 ram 1500
Posted By: elbaumpc
Subject: remote start, 03 ram 1500
Date Posted: October 07, 2009 at 2:36 PM
i want to have just my parking lights flash when i arm/disarm or use my remote start function. which wire would i tap into to have this work correctly and is a resistor or relay needed? i have a dei remote start/keyless entry system on my 2003 dodge ram 1500. thanx
Posted By: tommy...
Date Posted: October 07, 2009 at 5:05 PM
Parking LightsVIOLET / YELLOW(-)AT SWITCH
USE A 320 (OR A 1.4K) OHM RESISTOR... USE RELAY TO ISOLATE FROM SWITCH
M.E.C.P & First-Class
Posted By: tommy...
or next time...This site has it all... https://www.the12volt.com/installbay/vehicles.html
Posted By: elbaumpc
Date Posted: October 08, 2009 at 8:49 AM
could you explain a little further as to what i would need to do. i had that list all printed out but wasnt exactly sure what needed to be done to make it work. so i need to put a resistor inline on the 12v supply from the security system to the violet / YELLOW wire? please explain the relay install a little further.....? thanx
