2006 toyota matrix, python model 1400xpl
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=116825
Printed Date: May 06, 2026 at 2:02 AM
Topic: 2006 toyota matrix, python model 1400xpl
Posted By: buddyle2002
Subject: 2006 toyota matrix, python model 1400xpl
Date Posted: October 09, 2009 at 1:58 AM
Can someone please give me the basic wire instruction of which wire go from the car to the remote start. on the menu of the remote start, it has too many connections that i don't know if i need to use. And also use the xppresskit XK05. I don't know if this is correct, on the xk05 said hook the - brown to "ground when running (status)" on the remote system, is the "ORANGE" (H1/12) wire correct wire on the remote system?
what do they mean by purple color(starter side) and green color(key side)? I don't see it listed on the vehicle diagram.
this is what i am going to use, but if i missing something, please let me know.
H1 wiring diamgarm
h1/2---red "+constant power"
h1/3---brown "-horn"
h1/5---black "ground"
i don't need to hook up the 7 pins connection right?
"remote start ribbon harness wiring diagram"
heavy gauge relay satellite wiring diagram
purple---starter(starter side)
green----starter(keyside)--NOT SURE WHICH WIRES
red------12 volt
orange---accessory
red------12 volt
pink-----ignition 1
RED / white---12 volt
pink/white--ignition 2
auxiliary harness(h2) wiring diagram
i don't need to hook this up right? 4 pins connection
remote start "h3"
BLACK/ white----ground
violet/white---tach
brown----------break
gray-----------hood pin
door lock------IS THE BLUE IS FOR LOCK?
unlock---------AND GREEN FOR UNLOCK?
and a small text said---refer to techtip 1041 for wiring info? I don't have this info.
remote start auxiliary harness wire diagram
thanks for all your input!!!
Posted By: Mike M2
Date Posted: October 09, 2009 at 6:41 AM
When you cut the starter wire, you have a "key side" and a "starter side". The brown status wire goes to the blue staus wire on the RS aux harness. ------------- Mike M2
Tech Manager
CS Dealer Services
Date Posted: October 11, 2009 at 12:49 AM
you meant the xk05 wire - brown to "ground when running (status)" on the remote system; it's the BLUE WIRE from the remote start auxiliary harness wire diagram; 4 connectors right? Thanks in advance.
Date Posted: November 04, 2009 at 10:03 PM
thanks for all your help....it's very easy than i though it was. the problem i ran into is because i used the clip to connect each end of the wire together and didn't realize they are not contact each other. otherwise, everything work good. thanks for all you input.
