disabling daytime running lights on 545t
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=116835
Printed Date: May 06, 2026 at 4:02 AM
Topic: disabling daytime running lights on 545t
Posted By: cjrokke
Subject: disabling daytime running lights on 545t
Date Posted: October 09, 2009 at 2:19 PM
It took me all day yesterday, but I got my DEI 545t Night Light system installed. I found some things I didn't like while installing it like the way the parking lights flash when controlled by an auxiliary output. I got done at night, so now testing it in the day, I noticed that the headlights are always on. I noticed on the bottom of the install manual that it has daytime running lights. I do not want this feature. It says to disable it that I need to cut the red loop. I have no idea what this is talking about. The only red loop that I can remember is the power wire connecting the two relays. It seems to me that if I cut this wire, one of my relays wont work.
How do I disable the daytime running lights feature of the 545T?
(What red loop is it talking about?)
Posted By: Ween
Date Posted: October 09, 2009 at 3:45 PM
hi,
according to the manual, the red loop is inside the unit.  open the case and peek inside?
m
Posted By: Twelvoltz
Date Posted: October 09, 2009 at 7:20 PM
Ween is correct. The red wire loop is inside the case of the controller.
Posted By: cjrokke
Date Posted: October 09, 2009 at 7:50 PM
Yeah I found it. I never saw it when setting the duration. Mine was hiding under the plastic. Thanks for the input.
