power locks on a 1996 chyrsler sebring
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=116973
Printed Date: May 06, 2026 at 12:57 PM
Topic: power locks on a 1996 chyrsler sebring
Posted By: keving
Subject: power locks on a 1996 chyrsler sebring
Date Posted: October 15, 2009 at 9:03 AM
That's a Sebring Convertible JX
I installed a remote start box a while back, and that function works great. The unit also has a power lock feature, but I wasn't able to get it going. The instructions say to use a WHITE/ green wire at the back of the fuse box, feed it 12V to lock and 12V through a 1500-ohm resistor to unlock. While this sounds funky to me, nothing Chrysler does surprises me anymore, so I went with it. I fed 12V to every WHITE/ green wire I could find back there, but the locks never made a sound.
My questions:
1. Does this "one wire" scheme sound right to you? I can't find a wiring diagram for the locks on my car anywhere.
2. If it's not right, what is? A diagram would be nice.
Posted By: chev104275
Date Posted: October 15, 2009 at 9:55 AM
Power Unlock WHITE/ LIGHT GREEN (+) AT BCM MODULE AT FUSE PANEL BEHIND LEFT SIDE OF DASH
   PIN #8 OR #18 - USE A 1500-OHM RESISTOR IN LINE WITH THE UNLOCK OUTPUT AND ATTACH TO THE WIRE.
PowerLock WHITE/ LIGHT GREEN (+) AT BCM MODULE AT FUSE PANEL BEHIND LEFT SIDE OF DASH
   PIN #8 OR #18 - NO RESISTOR REQUIRED ON THE LOCK OUTPUT WIRE.
this is common on cryslers   its a multiplexed system     ALWAYS use a DMM before connecting to anything. your lucky you didnt fry anything doing that. you will need to use 2 relays for this use the relay section on this site for how to wire them
Posted By: keving
Date Posted: October 15, 2009 at 2:36 PM
Great!  I love having pin numbers, makes things so much easier when I know exactly where to look.  Shame more wiring diagrams don't mention pins or connectors.
Next question:  I also want to use the trunk pop feature.  The database on this site says the trunk release uses a GREEN/ black wire at the driver's kick panel.  Is there a pin/connector there, or is it just passing through on the way from the switch to the solenoid?
Date Posted: October 15, 2009 at 2:51 PM
looks like its gonna be the wire no pin numbers
