2007 chrys 300 base
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=116974
Printed Date: May 06, 2026 at 2:02 PM
Topic: 2007 chrys 300 base
Posted By: silverturtle1
Subject: 2007 chrys 300 base
Date Posted: October 15, 2009 at 9:15 AM
Installed an auto start / alarm with a bypass module and everything work perfectly except one thing. I left one of the accesory wired loose so I can connect it to the rear defroster, but I can not determine which wire to tape into
does any one have the wiring diagram for the center concol controlls, so I can determine the wire that activates the rear defroster? 2007 Chrysler 300 base
Thank you
Posted By: chriswallace187
Date Posted: October 17, 2009 at 10:38 AM
It's probably not going to be that simple, unfortunately.
If you'd like full, detailed wiring on your car go to ALLDATADIY. A great tool and a year subscription is about the same price as a Chilton's manual while having far better overall info. I highly recommend.
As far as getting the defroster to work with the remote start, it'd be helpful if you'd share the brand/model of the unit you installed, but in all likelihood the easiest way is going to be connecting a wire to the control terminal of the defogger relay. ------------- C Renner's Auto Electronix
Posted By: howie ll
Date Posted: October 17, 2009 at 11:52 AM
Welcome back CR, have you left economics for a while?
Date Posted: October 17, 2009 at 1:24 PM
Nope, just don't tend to watch the feed as much as I used to. Too much of a news junkie lately  ------------- C Renner's Auto Electronix
Posted By: SilverTurtle
Date Posted: October 17, 2009 at 2:57 PM
The alarm is an ungo sr9000 (made by clarion) hooked up with a fortin Evo-chr bypass module. There is a wire free to be connected to an accesory, and considering the wire that is connected to the defroster button just gets a pulse from the button, I assume taping into that wire would work?
Date Posted: October 18, 2009 at 12:27 AM
Can you describe the wire that's "free to be connected to an accessory"? Is this the orange heavy gauge wire you're talking about?
Also, does the Ungo you've got have a blue/white "2nd status/defogger output"?
Last - is the defroster switch standing by itself or is it part of the climate control panel in the center dash?
Date Posted: October 18, 2009 at 10:10 AM
its a thin blue wire, it is is the wire designated for a second output i.e. the defroster.
i dont have climate control, the defroster is its own button, but in the back is a harness with a bunch of wires that control diffrent buttons.
Date Posted: October 18, 2009 at 5:02 PM
I was probably confusing, but by "climate control" I didn't mean automatic climate control necessarily; three manual knobs/levers can also control the car's interior temps.
Also as to the defroster switch - what I was trying to figure out was whether or not you could see individual wires going to the switch, but if it's part of a panel which has a large single connector that answers the question.
I've done defogger connections on Chrysler Sebrings/minivans, and though they had quite a few wires on their climate control panel, none were capable of controlling the defroster directly. I had to wrap the defroster control wire from the remote start around the control terminal of the defogger relay in both cases, and it seems like you'll probably have to do the same.
Posted By: howie ll
Date Posted: October 18, 2009 at 5:26 PM
I'm with Chris here. It's probably easier to find the relay find the coil contact which either goes pos or neg when hot window switch, sorry you call them rear defrosters is pressed and wire to that. Having said that the next option would be to find the rear defogger power wire and relay that.
Posted By: syl20rochon
Date Posted: October 18, 2009 at 8:11 PM
I agree with you guys, going to the relay would be best since the rear defrost trigger is probably resistance triggered anyways.....I've checked with my wiring software and they do not supply any information on what needs to be done. I also check for data driven module that might get you the input, nothing.... ------------- Sylvain Rochon
MECP security specialist
Tech support for remote starters
26 Years of experience counts
I'm here to help.
