they try to steal my car
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=116983
Printed Date: April 02, 2026 at 3:36 AM
Topic: they try to steal my car
Posted By: attilab
Subject: they try to steal my car
Date Posted: October 15, 2009 at 3:44 PM
Hi
This is my first post, nice community.
Someone try to steal my car but looks like they couldn’t start it, now I can’t start it either.
They brook some stuff under the steering wheel and open the hood but I’m not sure what they did there.
When I put the key in ignition the lights and everything turn on but the car doesn’t start, I’m thinking it’s the starter disable feature that’s kicking in.
I have a 2000 Honda Civic 4 door with an old Alpine alarm system (not sure what model)
Any advice will be much appreciated.
Posted By: ceasar326
Date Posted: October 15, 2009 at 3:50 PM
It could also be a starter blown fuse. I would check that first, then the starter disable.
Posted By: KarTuneMan
Date Posted: October 15, 2009 at 11:28 PM
get under the dash a re-connect the starter wire.
Constant 12V+White Ignition Switch Harness
StarterBLACK/ White Ignition Switch Harness or White 6 Pin Plug behind Fuse Panel
IgnitionBLACK / YELLOW Ignition Switch Harness
Ignition 2Yellow Ignition Switch Harness
AccessoryYellow (+) Ignition Switch Harness
