viper 5901
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=116984
Printed Date: April 02, 2026 at 1:58 AM
Topic: viper 5901
Posted By: cpuguy06
Subject: viper 5901
Date Posted: October 15, 2009 at 4:29 PM
I'm installing a viper 5901 in a vehicle and wondering about a couple of the terms DEI uses in their installation guide. On the main heavy gauge wiring harness, they have the usual wires...Starter, Ignition..etc...however they have these other wires that, according to the installation guide, say they are supposed to be hooked up to the "polarity feed" for ignition 1, starter...etc. These wires are just supposed to connect to the wire they are the "polarity feed" for, right? Example: The polarity feed for ignition 1, should be connected to the ignition 1 wire, right? Thanks in advance!
Posted By: yimke
Date Posted: October 15, 2009 at 8:34 PM
polarity feed is more than likely the red wire right? Hook those all together to 12v+ constant because very rarely will you see a negative feed system.
