remote sunroof open/close
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=117138
Printed Date: May 09, 2026 at 2:25 PM
Topic: remote sunroof open/close
Posted By: pr8gg
Subject: remote sunroof open/close
Date Posted: October 21, 2009 at 1:40 PM
where can I get the wiring diagram for this: I want to be able to open/close the sunroof of my 2001 Mitsubishi Galant, with my remote alarm; also I would like to get the folding mirrors to close automaticaly with the activation of the alarm. can anyone help with the wiring? thanks in advance.
Posted By: t&t tech
Date Posted: October 21, 2009 at 8:15 PM
Have you done any testing yet? To know what kind of polarity is being switched at the suroof and the mirrors!
Posted By: howie ll
Date Posted: October 22, 2009 at 2:24 AM
The old FTO coupe had a wire on the switch where you applied a 1 sec pos pulse, this closed the mirrors. As for the roof I'm with t&t here. Also on that vehicle the windows are powered  (1 touch up-down driver's door) for 1 minute after turning off the ignition, does this also apply to the roof, in that case what you want isn't neccessary.  Also is there a trap in the roof?  i.e. it closes to about 4" then stops?
Posted By: metz35
Date Posted: October 23, 2009 at 6:19 AM
every mitsubishi i have ever done is a single negative pulse to open the roof if its a one touch open, and a negative threw a pulse timer relay set to about 8-10 seconds to close but the sunroof motor needs to have a constant 12v if your gonna open and close via remote. so a) you can run a 12v wire to the motor and get rid of the ignition supply or b) you can use another aux and turn the ignition on with a relay....i suggest a option a....
Posted By: installjunkie01
Date Posted: October 23, 2009 at 6:54 AM
DIRECTED ELECTRONICS P/N# 529T will open your sunroof, it controls 1 window in 2 directions, or 2 windows in 1 direction, for more control, use a 530T, as it controls 2 windows in both directions, & it is not that expensive, maybe 30 bucks or so!
