no doors on the car, will the alarm work?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=117417
Printed Date: May 04, 2026 at 11:48 AM
Topic: no doors on the car, will the alarm work?
Posted By: crazy curt
Subject: no doors on the car, will the alarm work?
Date Posted: November 02, 2009 at 11:08 AM
Hi guys, attempting to install an alarm in a dune buggy and it does not have doors to notify the brain that we have gotten in or out of the car. Can I just leave all those signal wires unconnected and use the remote buttons to arm and disarm the alarm? I am installing a Steller STRS9750 Remote Start and Alarm in this thing and would like to have some protection while in the desert.
All the wiring is custom to this project so there is no make or model of car that I can provide to help with your answer.
Thanks in advance for any help you can provide.
posted_image
posted_image
Curt
Posted By: kassdog
Date Posted: November 02, 2009 at 11:38 AM
Just leave those wires disconnected. I would suggest installing a motion sensor though since its completely open. They are pretty cheap too, between $50-$100.
Date Posted: November 02, 2009 at 12:05 PM
Thank you Kassdog, it has a Dual Stage Shock Sensor that was included in the kit it is already plugged in, are you recommending a Radar Style motion sensor in case someone reaches inside?
Thanks again!
posted_image
Curt
Posted By: Mark Mizenko
Date Posted: November 02, 2009 at 12:15 PM
I would reccomend it.  Have some type of control over it also.  Like a toggle switch to disable it, for times when you want the regular alarm, but not the perimiter field sensor active.
Posted By: number2
Date Posted: November 02, 2009 at 2:49 PM
Does the seat have any shock absorption that would allow you to install a pressure switch?
Date Posted: November 02, 2009 at 3:16 PM
Hello Number2, no, the seat does not have shock absorption. It does have suspension seats but that is only because of the webbing between the steel framework. Curt
Curt
Posted By: KPierson
Date Posted: November 02, 2009 at 4:22 PM
One thing to keep in mind is that some alarm systems require you to open a door to program them.  If your alarm is like that you will need to ground out the door trigger in order to set the system up.
Kevin Pierson
Posted By: jcs091570
Date Posted: November 03, 2009 at 9:56 PM
I would go with a Proximity Sensor 508D. When calibrated and installed properly, these work great. You can always bypass warn away with remote when arming.  Whether it will work with Stellar I am not sure. You could always hard wire it to the alarm brain harness on one of the trigger wires.
