99 mustang start problem
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=117468
Printed Date: May 05, 2026 at 5:45 PM
Topic: 99 mustang start problem
Posted By: mike636r
Subject: 99 mustang start problem
Date Posted: November 04, 2009 at 3:03 PM
I have a 99 v6 mustang automatic,about 1 month ago i was installing a remote start,to which i ran into some issues...here is what happened.
Car would crank but not start,{theft}light rapidly blinking.I thought it was a (Pats) problem.today i brought a locksmith to my house to reprogram the keys.I let him do his thing and this is what he said..
''I plugged in the computer and the car is not communicating with the tool.I also used a master key to which the car was not responding,ive never seen anything like this before''
He said it could be the computer,does anyone know why the plug in tool would not communicate with the car?{specific}
Thanks.
Stage 3 body kit,side exhaust,Roush lowering springs,k&n filter,ported & polished throtel body.and gonna add a cobra supercharger.
Posted By: metz35
Date Posted: November 04, 2009 at 3:41 PM
seen this problem in a 2005 honda accord...ecu was fried.....wouldnt turn over and hondas portable computer wouldnt connect to the car...1900$ and one ecu later, all was fine.
Posted By: chriswallace187
Date Posted: November 04, 2009 at 9:49 PM
mike636r,
What kind of bypass are you using, and how do you have it connected?
C Renner's Auto Electronix
Posted By: mike636r
Date Posted: November 04, 2009 at 10:38 PM
Thanks for the replies!
Chris,
i was using a universal bypass module(556 uw)
Since i could not get the remote start to work,i have removed All remote start connections and taped up all the cars wires back like they were. any ideas why the plug in code reader is not communicating with the car?
Date Posted: November 05, 2009 at 12:48 AM
That's tough to say, especially since you were using a universal bypass. If you'd say, hooked up 12v or ground directly to one of the data lines from the immobilizer receiver it might have been expected, but there's obviously no need to do that with a 556U.
Was the car starting with the key before this? Is it starting now, despite the non-communication with the scan tool?
Posted By: mike636r
Date Posted: November 05, 2009 at 2:24 AM
Yes,the car was running perfectly and so was the scan tool with the car..
I'm just not sure what it can be other then fuse and relays(which i have checked) over and over again..
I'm thinking towards a burned computer? who knows?
Date Posted: November 05, 2009 at 4:00 AM
It could be, but what wires would you have connected to cause that? You were testing the wires with a meter prior to making connection, right?
Posted By: mike636r
Date Posted: November 05, 2009 at 4:25 AM
yes, i tested every wire except for the tach wire.Instead i used a color coded diagram which told me the pin # and color which was located at the (ecm).I didn't feel the need to check because it matched with the info i got.
also, i noticed the odometer reads --------------.
is this a clue of a erased or burned ECM?shouldn't a fuse or relay go out before the ecm would?
I'm never buying a pats equipt vehicle.what a pain!
