idata bypass
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=117487
Printed Date: May 06, 2026 at 2:04 AM
Topic: idata bypass
Posted By: jrat69
Subject: idata bypass
Date Posted: November 05, 2009 at 5:34 PM
I just installed my alarm/rs. 2008 Toyota Tacoma DC 4x4. Installed the RS-900 with the idata ADS-TBSL-KO using the data link cable. It doesn't program. I have tried resetting it, and re programing. According to the manual there's not many wires to hook up. A ground, Keysense, Data cable, and the code and txct. It starts fine with the key in switch, but without the key, it just cranks. When cranking I checked the status light, it was off. The book shows "module diagnostics during start... LED off......Invalid Ground when running status from RS" The ground out when running wire isn't used when using the data cable.
What is wrong?
Posted By: beegbie
Date Posted: November 05, 2009 at 5:50 PM
Is the firmware version 1.5 or 2.0?
Posted By: Mike M2
Date Posted: November 05, 2009 at 6:47 PM
You need to hardwire it. We have had so many issues with the data wire it isn't funny. Hardwire it before you try any other fixes.
Has it been recently flashed? The version out now(V2) wires differently than the old version. If you didn't need to cut the code wire to connect it you are wired for V2.
Mike M2
Tech Manager
CS Dealer Services
Posted By: jrat69
Date Posted: November 05, 2009 at 6:50 PM
I don't see a firmware # on it or the box.
Here's what it says on the box:
P/N & SW   ASS-TBSL-KO
HW ADS-TB (16)
Guide 415
Date 2009-2-19
t/c XOEEDB66B7
Posted By: jrat69
Date Posted: November 05, 2009 at 6:55 PM
Didn't need to cut any wires on my vehicle according to the wiring instructions. Toyota Tacoma is Type 2. If I hard wire it, there is only three connections, 12v+, Ground, and the Ground out when running.I'll try that.
Posted By: OhioMike1101
Date Posted: November 05, 2009 at 7:34 PM
sounds like you need to flash the module if you haven't yet.  To flash the module requires the USB flasher.
South Side Audio
2501 S. High St
Columbus, OH 43207
Posted By: Mike M2
Date Posted: November 05, 2009 at 8:08 PM
What guide number are you using to install it with?
Mike M2
Tech Manager
CS Dealer Services
Posted By: jrat69
Date Posted: November 05, 2009 at 8:28 PM
Rev Date February 10, 2009
Doc No 00835.
It did not come with the install guide, I downloaded it from iData.
Posted By: jrat69
Date Posted: November 05, 2009 at 8:34 PM
There are some numbers on the bypass,
one is TB16kv1.32
Is this a software version #?
Posted By: jrat69
Date Posted: November 05, 2009 at 9:29 PM
How do I tell what software version is on this?
Posted By: jrat69
Date Posted: November 07, 2009 at 8:44 PM
OK I hard wired it, still nothing. I rechecked all the connections, we had the code and TXCT wires crossed, fixed that done a reset, tried to program, still doesn't work.
After I do the reset, I plug the other 2 connections back in. Then press the and release the program button. The light flashes two quick flashes (hard wired) I press the program button, it turns solid red then goes off. I release the program button and insert key. It the light stays off.
How can I tell if it's version 2.0? It does not say anywhere on the box or the module. The only reference I find on iData's Webb site does not mention any different firmware versions. I only found the one guide, which does not show cutting the wires. If there is a older version of this guide what number is it? The one I downloaded is 835 dated Feb 10,2009, my module has a date of Feb 16, 2009. I would think this would be the right manual. As long as I leave the key in the ignition, it starts fine, so I know it is something with the module. Is it bad? do I need a new one, if so should I try another idata, a fortin, or a dei?
Posted By: jrat69
Date Posted: November 07, 2009 at 9:57 PM
OK I feel really stupid now. When I was asked which guide version I was using, I was using 835. When I looked back over all my info I realized that it said guide 415 on the box. I downloaded 415, it show that you cut the wire, actually a completely wires differently. I rewired, reset programed (instantly) and it works!!!!!!!!!!!! Now I need to spend a couple of hours cleaning up and securing all the wiring, mounting the brain adjusting the shock sensor, (it goes off when I shut the door)and then putting everything back together.
To all who replied, THANKS!!!!!!!!!!!!
