dodge mux wire
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=117562
Printed Date: May 02, 2026 at 2:52 AM
Topic: dodge mux wire
Posted By: mobiletint
Subject: dodge mux wire
Date Posted: November 08, 2009 at 8:25 AM
Ive done these since they came out building the relays and resitors, now I just use the idatalink bypass for most of my installs.
Recently I had one without a transponder key or factory alarm. So in order to bypass the Mux wire with my compustar 5200 I used the second start and second sccesory negative outputs. 180ohm on the second start and 600 on the second accesory. Saved time and parts.
I guess you could use this info on a start only for jeeps that use the ADS C2 ring and have keyless on the key as well.
Posted By: Velocity Motors
Date Posted: November 08, 2009 at 10:08 AM
We had this on some vehicles about 2 years ago and we did the same thing. Worked like a charm too, it's odd that Dodge would put out these vehicles without a chip in the key seeing that 99.9 % of the other vehicles have the Sentry system installed.
