toyota echo 1999 2000
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=117626
Printed Date: May 06, 2026 at 7:53 AM
Topic: toyota echo 1999 2000
Posted By: delchapin
Subject: toyota echo 1999 2000
Date Posted: November 10, 2009 at 12:06 PM
Hello
Maybe I have an easy problem, but I can not fix
I got a TOYOTA ECHO 1999-2000.
I can not disassemble the front panel to make the respective INSTALLATION
comes all in one piece
any help is good
 ------------- Novice Audio Security
Posted By: howie ll
Date Posted: November 10, 2009 at 12:34 PM
Undo the steering column cowling to get at the wiring.
Date Posted: November 10, 2009 at 12:44 PM
Thanks, Thanks howie ll
that looks easy, I wanted to disarm all
like the others.
Where can I find the PIN of the 4 doors, safer or Easy?
(No electric system brings with it doors Manual)
pending
Posted By: t&t tech
Date Posted: November 10, 2009 at 5:43 PM
In alot of the new gen toyotas i come across, when the dash piece is all in one like that, you would normally find most of the wires you would need behind the pasenger glove compartment! It's where i go! I do entire alarms and starters without even working on the driver side! Makes the install alot safer to!
Posted By: syl20rochon
Date Posted: November 10, 2009 at 6:40 PM
All door pin are in the driver's kick panel at the harness going to the rear. The color RED / white (-).....
------------- Sylvain Rochon
MECP security specialist
Tech support for remote starters
26 Years of experience counts
I'm here to help.
Date Posted: November 11, 2009 at 12:07 AM
Thanks to all
Solved the QUESTIONS
PIN 2 Photos of the doors
Red and White (-) Safe and Easy
until the next
Date Posted: November 11, 2009 at 12:36 AM
Sorry I could not edit the response to POST To delete the links not working  ">  ------------- Novice Audio Security
Posted By: howie ll
Date Posted: November 11, 2009 at 2:09 AM
Also on most modern Toyotas there's room behind or to the side of the glove box or adjacent to the head unit to mount the alarm module.
Date Posted: November 11, 2009 at 12:41 PM
Yes, thank you was not as open, but stay well all readily accessible the same for the speaker to the front well hidden. this will help those who arrive in the future here.
