viper 5702 unable to disarm with remote
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=117774
Printed Date: May 14, 2026 at 3:33 PM
Topic: viper 5702 unable to disarm with remote
Posted By: wgrassie
Subject: viper 5702 unable to disarm with remote
Date Posted: November 16, 2009 at 2:19 PM
1993 Sentra GXE
Hi
I installed th Viper 5701 in my 1993 Sentar GXE- experiencing the following issue:
  • Remote Learn (Default Setup) completed succesfully - alarm sounds etc.
  • The system arms -doors lock
  • System will not disarm with remote
  • Turn the ignition key to on and the alarm sounds- Thanks
Any help would be appreciated-Thanks
Thanks for your help
Posted By: t&t tech
Date Posted: November 16, 2009 at 3:25 PM
Have you programmed the remote to the default setting?
Posted By: 05gt
Date Posted: November 16, 2009 at 11:05 PM
you usually have to program it to the standard configuration in the manual I believe (disregard my post, I thought you were trying to program additional remotes to the brain)
Posted By: yimke
Date Posted: November 17, 2009 at 2:24 PM
disarm it for now by turning the ignition on and pressing the valet button once (if you did not change the setting)
The valet button is on the antenna receiver.
Posted By: wgrassie
Date Posted: November 17, 2009 at 10:20 PM
1993 Sentra GXE
Alarm deactivated with Valet Key
  • Reset features to factory default
  • System will NOT arm or disarm with remote
When I try to program the remote;
  • press f for 12 seconds
  • remote emits 1 long beep
  • I press and hold unlock command for 1.5 secs
  • remote beeps twice and stays on
  • The arm, disarm and remote start & aux leds DO NOT turn on
