radio run on and remote start
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=117801
Printed Date: May 13, 2026 at 10:09 PM
Topic: radio run on and remote start
Posted By: asstpumpslimm
Subject: radio run on and remote start
Date Posted: November 17, 2009 at 12:07 PM
ok hopefully my last thread here as i seem to have just about everything done now. im about to hook the accessory wire and climate control wire up to the relay satellite. for running both of those wires off the acc will i need a relay or is the relay satellite good enough
anyway 1995 cadillac fleetwood and viper 5900. if i remote start it works fine, if i shutdown remote start from the remote. the radio starts playing like i just cut the key off and with the cadillacs it has the feature where the radio doesnt go off till the drivers door is opened.
how to fix
Posted By: chev104275
Date Posted: November 17, 2009 at 12:56 PM
find the drivers door pin and pulse it using the Factory rearm wire from the 5900
the pin should be negitive test first i belive that has independent pins on the door frame
------------- If i Can't Install it I Don't need it Joe
Date Posted: November 17, 2009 at 4:54 PM
no it doesnt have door pins. everything is built into the latch inside the door, but i know which one is the door trigger. so hook up a relay and run the rearm to the door trigger
