dei learn mode but wont lean remote
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=117818
Printed Date: May 13, 2026 at 4:00 PM
Topic: dei learn mode but wont lean remote
Posted By: ove_98 tsi
Subject: dei learn mode but wont lean remote
Date Posted: November 17, 2009 at 9:49 PM
hi i have a python 1090 i just bought and i am doing the install myself thanks to this site. my problem is that i go to the learn routine
open door
ign on
press valet once the press and hold
i then get my single flash of the led and single chirp but when i push the lock button on the remote nothing happens. so i figured the brain or remote might be bad, i sent them back to the company and they sent me new ones. so i try it again...same thing :(
can anyone please help
also i do not have the remote start hooked up but i wouldnt think this matters since it does enter the learn mode
thanks
------------- holset powered talon
Posted By: howie ll
Date Posted: November 18, 2009 at 2:10 AM
Is the green wire connected to a door trigger and going to ground? Test; also are you manually programming or using a bitwritwer? It's unlikely from new but it's possible that the learning cycle has been programmed out by the bitwriter. t&t knows the correct procedure. That apart excluding Clifford G4 and some G5, I find DEI product a bitch to programme, lots of patience and multi attacks before it works.
Posted By: t&t tech
Date Posted: November 18, 2009 at 1:34 PM
From your description it's entering the learn mode, have you checked your antenna connections?
Posted By: jim hunter
Date Posted: November 18, 2009 at 3:13 PM
im not familiar with the new dei product line but are you sure that step 1 is auto learn? older dei that i used were usually like step 7 or 9 for auto learn?have you tried entering the programming mode and programming each button individually?
Posted By: t&t tech
Date Posted: November 18, 2009 at 7:42 PM
I agree with you jim, but with dei what I noticed personally is that even though it's the wrong program menu once the brain opens up for remote rogramming once a signal is emmited by a compatible remote the system should still respond! of course i could be wrong as i'm not familiar with that new python line for the time being!
