ford f 250 5902 window module
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=117824
Printed Date: May 13, 2026 at 7:47 PM
Topic: ford f 250 5902 window module
Posted By: geek1503
Subject: ford f 250 5902 window module
Date Posted: November 18, 2009 at 9:21 AM
Does any know how to wire up a window module on a 2009 F250 this truck has a harness the plug as you can see from the picture. posted_image
Posted By: howie ll
Date Posted: November 18, 2009 at 9:24 AM
What exactly are you asking?  Window close with alarm or locking? Adding and wiring up power windows?
Posted By: geek1503
Date Posted: November 18, 2009 at 9:34 AM
On the older trucks you have a boot to run the wires to the window switches, thats where you wire up the window module for the window roll down and windows roll down with the aux button on the remote or when you arm the alarm the windows roll up. Since the truck has a pug in harness do you tap into the cables from the harness or do you need to make a new boot for the door and run the wires to the switch separately.
