2002 golf tach wire
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=117930
Printed Date: April 30, 2026 at 9:36 PM
Topic: 2002 golf tach wire
Posted By: riz k
Subject: 2002 golf tach wire
Date Posted: November 22, 2009 at 12:04 PM
Hi i have a 2002 volkswagen golf 1.4 which i am installing remote start on can anyone tell me the colour of the tach wire and where its located. thanks
Posted By: howie ll
Date Posted: November 22, 2009 at 5:15 PM
If it has a coil it's light GREEN/ red at the coil, otherwise the injectors, any of the odd coloured wires.
Posted By: riz k
Date Posted: November 23, 2009 at 3:26 PM
thanks for that howie is there any way i can find it inside the car to save me running the wire into the bay.
Posted By: howie ll
Date Posted: November 23, 2009 at 4:58 PM
No but then you have to run Siren and hood switch wires through (although you can pick up hood switch inside depending on whether or not there's a factory alarm and or factory power windows, if so you've got to get into the driver's door for the locks and window close as well). Drop the glove box and come through the main grommet on the nearside. It's a fussy car, the ignition and starter wires are a nightmare, you will need a 556U for the bypass, what make of alarm R/S are you using?
