python 581xp neutral safety wire
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=117932
Printed Date: April 30, 2026 at 9:36 PM
Topic: python 581xp neutral safety wire
Posted By: dlek
Subject: python 581xp neutral safety wire
Date Posted: November 22, 2009 at 1:17 PM
I am installing a Python 581xp remote starter into a 1996 Chevrolet Lumina sedan 3.1L.  On the wiring diagrams I have seen, the Lumina does not have a neutral safety wire.  Is that correct?  How do I prevent the system from starting the engine while the transmission is in drive?
Thanks!
Posted By: Mark Mizenko
Date Posted: November 22, 2009 at 6:35 PM
What color is the starter wire in the vehicle?  Yellow or Purple.  If it's yellow, I think you're ok.  Purple.. you'll need to make an interface,  because it'll be able to start in gear,  You can do the whole install and test it.  If it starts in gear, you can wire an interlock in.
Posted By: 91stt
Date Posted: November 22, 2009 at 8:56 PM
If you connect the start wire to the yellow wire at the ignitions switch, you will be fine like Mark said. This wire is electrically disconnected from the starter relay by the transaxle range switch in all positions except park and neutral.
Posted By: dlek
Date Posted: November 23, 2009 at 10:16 AM
The wire is yellow in this vehicle, thanks for the info!
Posted By: 91stt
Date Posted: November 23, 2009 at 3:40 PM
but it is violet after the theft deterrent relay which is also under the dash. as long as you don't tap into that wire, you should be safe.
