viper 5101 on 2002 toyota tacoma
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=118117
Printed Date: April 29, 2026 at 8:36 PM
Topic: viper 5101 on 2002 toyota tacoma
Posted By: phorsfi
Subject: viper 5101 on 2002 toyota tacoma
Date Posted: November 30, 2009 at 9:46 AM
Hey all,
Looking for a little help wiring this keyless/Rs unit up in this new to me truck. The truck came with an old Audiovox (from what I can tell) alarm and immobilizer installed and of course no remotes, so anytime I work on the truck it goes into alarm mode and is inoperable.
I've decided to replace the old system with a Viper 5101 Keyless entry and remote start system but was hoping someone with access to directechs.com could help me with the pinnout's and locations around the truck.
Any help is more than appreciated, I don't really want to jump into this blind if at all possible.
Thanks!
Patrick
Posted By: Chris Luongo
Date Posted: November 30, 2009 at 10:12 AM
Directechs is hard to get into.
techservices.audiovox.com you can sign up for an account there all by yourself. www.bulldogsecurity.com has some information as well.
The Audiovox system that's installed should already give you a head start. Of course you always want to test all wires, but, follow the harness from the Audiovox to where it connects to the car and you should find this:
small red: lock
small green: unlock
red: constant
yellow: ignition
black: ground
brown: door trigger
white: parking lights
Posted By: phorsfi
Date Posted: November 30, 2009 at 7:14 PM
Okay, I've manages to install the system (6 hours of banging my head wondering why i didnt just get someone to do it for me) and it seems to work except for the remote start.
I've got it so that it honks and flashes the lights when you lock/unlock the doors however when trying to remote start the vehicle it gives me 7 light flashes which means something along the lines of "manual transmission mode is enabled and not initialized"
so i read up in the manual how to initialize manual transmission start mode and it says:
with the vehicle running, shift the transmission into neutral, step on the brake, apply the parking brake. Using the remote control activate the remote start withing 15 seconds, the park lites will flash 5 times to confirm. turn off the ignition (car will continue to run), exit the vehicle, car will shutdown upon locking the door.
well thats fine and well, but my remote dosnt seem to work at all when the vehicle is running, i dont hear any relay's click, i dont see any led flash's nothing... Anyone have any idea's?? Im running out of steam trying to troubleshoot this thing!
Patrick
Date Posted: November 30, 2009 at 9:03 PM
Is the truck an automatic or manual?
If it's an automatic, you'll want to ignore all of that paragraph, and simply enter programming and set the unit to auto-transmission mode.
If it is a manual transmission, either one of the safety inputs (brake, parking brake, neutral safety, hoodpin, on/off control switch) is not correct, or, the produre to put the unit in "reservation" mode is not being followed correctly.
I've never installed a DEI unit in a manual transmission cars, but the other brands I've used (Ultra and Compustar) have you step on foot brake, apply parking brake, release foot brake.
Read through the DEI's manual as carefully as possible (maybe even the owner's manual instead of install manual)....I feel pretty sure you have to release the foot brake before engaging the unit.
Posted By: phorsfi
Date Posted: November 30, 2009 at 9:43 PM
The truck is a manual, I had forgotten to install the on/off control switch (not that it changed the situation at all)... does it help to know that even the lock/unlock function doesn't work when the vehicle is running??
I'll double check all the safety inputs in the morning, but as of this afternoon I was sure they were all functioning correctly... As far as the clutch bypass for starting I used a "grounded when active" conductor to the output of the clutch switch to make the truck think it was depressed and allow it to start...
However none of this really matters as im still stuck at the part about enabling Manual Transmission Starting and waiting on getting the park lites to flash 5 times confirming that remote start is active...
ANY idea's are helpful guys,
Thanks alot!
Patrick
Posted By: zerepdivad
Date Posted: November 30, 2009 at 10:16 PM
Neutral safety i believe has to be tied into the parking brake and you HAVE TO learn tach, and hook up door triggers. DId you do all of this?
------------- A DMM is a beautiful thing.
Posted By: phorsfi
Date Posted: November 30, 2009 at 10:37 PM
let just make sure I have a few things correct here:
on the "RS In" 5 pin connector:
Blk/Wht Wire - Neutral Safety Switch (-) Input - Connected to the Parking Brake switch, grounded out when engaged...
Voilet/Wht - Tach Wire - Connected at Igniter (pass side inner fender)
Brown - Brake Shut Down (+) Input - Connected to Brake switch @ pedal to +12v switched brake light lead.
Gray - Hood Pin Switch NO/NC (-) Input - connected to hood pin switch, isolated when hood closed, grounded when hood open.
Blue/White - 2nd Remote start status / Defogger - Not used
Does this sound correct?! I believe it is...
On the H3 Heavy Gauge 8 pin connector:
Pin 2 - RED / Wht - 12v (+) Fused 30A Input (contact 87 of RS Flex Relay)
Pin 5 - Red - 12v constant (+) Fused 30A Input (for ignition 1 relay)
Pin 8 - RED / Blk - 12V (+) Fused 30A Input (for accessory and starter Relays
I've connected all 3 of these leads to constant 12V power direct from the battery...
This sounding okay?
Date Posted: November 30, 2009 at 10:43 PM
All sounds ok but did you LEARN tach? Start the vehicle by key and hold the valet button on the antenna until the blue led lights up?
Posted By: phorsfi
Date Posted: November 30, 2009 at 10:51 PM
I just read your message a few moments ago and ran outside to do that... I must have missed that step in the install manual! it works, it stays running as you exit the vehicle and is ready to start again once the doors lock.
Thank you thank you!
I will have to look at my clutch safety switch bypass as the ignition and such comes on when trying to remote start but no cranking, same as if you forget to push the clutch in...
This forum is amazing, thanks everyone, you guys are great, I hope to learn alot more from you guys in the coming months!
Patrick
Date Posted: November 30, 2009 at 10:55 PM
Yup no problem. Let us know if ya get the clutch thing figured out.
Posted By: phorsfi
Date Posted: December 01, 2009 at 2:25 PM
Okay, I am having no luck with the clutch bypass, perhaps im missing something...
Originally I had the "grounded while running" wire connected, turns out this doesn't work as I had expected it to.
Next I tried a 12v tap from one of the acc. wires of the remote start. Turns out this kept the starter motor running all the time when starting the vehicle. This lead me to believe that it was a "direct feed" type system.
Believing it was direct feed I next tried a jumper from the clutch switch to the purple starter wire from the RS. I figured this would enable the starter motor when the RS wanted to start the truck, no luck.
Any Idea's??? has anyone done a clutch bypass on a 1996-2004 Toyota Tacoma and want to share the secret with me?
Thanks,
Patrick
Date Posted: December 01, 2009 at 5:20 PM
OK well what wires do you have at the clutch switch? What do they read when pushed in?
Posted By: phorsfi
Date Posted: December 01, 2009 at 7:20 PM
I managed to get the clutch bypass issue sorted, I wired up a relay to close the switch when the remote start was activated, works great!
I started taping up my bundles and put the unit up into the dash and now my power unlock doesn't work... I've checked my connections and everything seems good, I dont know what to do now...
Blue from alarm (+) Lock (-) Unlock --- Connected to Red w/ Yellow Stripe @ Fuse box
Green from alarm (-) Lock (+) Unlock --- Connected to Back w/ Blue stripe @ fuse box
These were the connections the original alarm used and were working fine until just now.
