90 acura integra defrost
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=118270
Printed Date: May 03, 2026 at 6:42 AM
Topic: 90 acura integra defrost
Posted By: pitoaudiovisual
Subject: 90 acura integra defrost
Date Posted: December 06, 2009 at 2:29 AM
i have an issue with my defrost. sometimes it works and sometimes it doesnt. the fuse is good so how do i check to see if its the switch or the actual defrost bad. thanks in advance
Confidence is the key to any project!!
Posted By: i am an idiot
Date Posted: December 06, 2009 at 8:45 AM
Using a volt meter, test for voltage at the connector at the window.  There are going to be 2 connections.  One meter lead on one and the other meter lead on the other connection.
Date Posted: December 06, 2009 at 3:51 PM
should i check the voltage with the switch on or off cause the sometimes the switch light goes on and it will work but sometimes the switch doesnt light up and the defrost dont work at all
