06 town and country ignition wire loc
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=118287
Printed Date: May 02, 2026 at 7:27 PM
Topic: 06 town and country ignition wire loc
Posted By: sneakycyber
Subject: 06 town and country ignition wire loc
Date Posted: December 06, 2009 at 7:28 PM
Where is the best place to grab the ignition wires. I looked in the column and the wire colors didn't match any diagrams I have. I have an Audiovox one, Direct wire, and the on off this site there all the same. Where I looked, Key cylinder is on the right side of the column and it connects to the ignition switch on the left. I found Starter 1, Ignition 1, and I think acc. I can't find the key sense wire or the second starter wire. I will be using PKUMUX since the owner has an all in one keyfob/ignition key. Should be an easy install it was my 6th car today and we didn't have the bypass in stock so I will be doing it next Saturday. Was hoping to get the starter in but I gave up and called it a night.
P.S. Starter is a Valet 562T
Posted By: monty_77
Date Posted: December 06, 2009 at 8:08 PM
key sense wire and second starter are the same PURPLE / brown at the ignition harness
Posted By: kreg357
Date Posted: December 06, 2009 at 8:20 PM
I believe they are the same as the 2006 Dodge Caravan.  I got the wires in the steering column.  You only need 3 wires.
Starter   (+)                    Yellow
Ignition 1  (+)                 Pink/White
Starter 2   (aka MUX)   PURPLE / Brown
posted_image
All listings I have show Keysense as NA.
Date Posted: December 17, 2009 at 3:28 PM
Ok I got the starter done but the factory keyless doesn't work when the vehicle is remote started. Did I miss an accessory wire? I have Pink/White, Yellow, And I think Violet/orange not sure because some of the accessories run without this wire. I don't have the van in front of me and won't until Saturday when I go back to my brothers. I thought it wouldn't work because the vehicle is running but it works with it running on the key. I should have made him get the other key so I could finish it the first time. Thanks for the help.
Posted By: zerepdivad
Date Posted: December 18, 2009 at 11:19 PM
I did one today and only hooked up the ignition, and starter 1, and it started up just fine multiple times. Factory keyless worked with the car running as well. I used a 556u on it though, and it had regular keys with a separate fob for keyless.
A DMM is a beautiful thing.
