03 suzukit vitara
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=118343
Printed Date: May 01, 2026 at 7:33 AM
Topic: 03 suzukit vitara
Posted By: pitoaudiovisual
Subject: 03 suzukit vitara
Date Posted: December 08, 2009 at 10:32 AM
im doing a remote starter for an 03 suzukit vitara and i got the paper work for a grand vitara and it is not the same wires so does anyone have the paper work for a vitara thanks in advance
Confidence is the key to any project!!
Posted By: chev104275
Date Posted: December 08, 2009 at 11:08 AM
2003 SUZUKI VITARA 4DR SUV
Remote Start
WIRE COLOR POLARITY LOCATION
Battery WHITE/ YELLOW (+) IGNITION SWITCH HARNESS
Ignition 1 BLACK/ WHITE (+) IGNITION SWITCH HARNESS
Accessory 1 YELLOW/BLACK (+) IGNITION SWITCH HARNESS
Starter 1 BLACK / YELLOW (+) IGNITION SWITCH HARNESS
Parking Lights RED / YELLOW (+) AT VEHICLE FUSE PANEL
Reverse Lights RED (+) IN HARNESS IN DRIVER KICKPANEL TO REAR
Doorlocks/Windows
Power Unlock PINK/GREEN (-) AT DOORLOCK CONTROL MODULE TO RIGHT OF GAS PEDAL BEHIND CENTER STACK
PowerLock PINK (-) AT DOORLOCK CONTROL MODULE TO RIGHT OF GAS PEDAL BEHIND CENTER STACK
this is from audiovox
Posted By: ckeeler
Date Posted: December 08, 2009 at 8:29 PM
is it a grand vitara? if not, are you positive it's not an 04? what is the 10th digit of the vin?
