2007 miata wiring
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=118385
Printed Date: May 04, 2026 at 11:28 PM
Topic: 2007 miata wiring
Posted By: n2vsw
Subject: 2007 miata wiring
Date Posted: December 09, 2009 at 10:01 PM
Hello everyone. I wanted to know if anyone has the wiring print/locations for a 2007 Miata. I am installing a 727T and have proceeded to start opening up some of the dash panels. Any help would be greatly appreciated. Thanks
Posted By: monty_77
Date Posted: December 10, 2009 at 12:38 AM
Mazda MX-5 Miata 2007
WIRE COLOR LOCATION POL.
Battery 1 WHITE/ Green [40A] Ignition Switch, 6 Pin Plug, Pin 3 Positive
Ignition 1 GREEN / WHITE Ignition Switch, 6 Pin Plug, Pin 2 Positive
Starter 1 WHITE/ Blue Ignition Switch, 6 Pin Plug, Pin 1 Positive
Accessory 1 Pink/Black Ignition Switch, 6 Pin Plug, Pin 4 Positive
Parklights Positive BLACK/ Green Junction Conn. Below Fuse Box In Driver's Kick Positive
Parklights Negative BROWN / Black At Light Switch, 17 Pin Plug, Pin 12 Negative
Brake Lights BLACK / YELLOW Junction Conn. Below Fuse Box In Driver's Kick Positive
Horn GREEN/ Orange Keyless Module Left Of Steering C. In Gray Con. Negative
Tach RED / Black At Cam Sensor On Top Of Engine Near Firewall 4 Cyl.
Lock BROWN / White (1) Keyless Module Left Of Steering C. In Gray Con. - 1 KOhms
Unlock BROWN / White (1) Keyless Module Left Of Steering C. In Gray Con. Negative
Trunk Purple Keyless Module Left Of Steering C. In Gray Con. Negative
Driver Door Unlock Gray (1) Keyless Module Left Of Steering C. In 6 Pins Con. Reverse
E-Brake Gray At Junction Conn. At Right Of Gas Pedal Negative
Clutch GREEN / WHITE (2) At Clutch Switch Negative
OEM Hood Switch Gray Keyless Module Left Of Steering C. In Gray Con. Negative
Disarm Gray/Red (3) Keyless Module Left Of Steering C. In Gray Con. Negative
Rearming Gray/Red Keyless Module Left Of Steering C. In Gray Con. - 1 KOhms
Trunk Disarm Brown Keyless Module Left Of Steering C. In Gray Con. Negative
Dome Sensor BLACK/ Blue Keyless Module Left Of Steering C. In Gray Con. Negative
Trunk Pin Orange Keyless Module Left Of Steering C. In White Con. Negative
KeySense BROWN / Red Keyless Module Left Of Steering C. In White Con. Positive
Door Pin FL Blue/Black Keyless Module Left Of Steering C. In Gray Con. Negative
Door Pin FR BLACK/ Blue Keyless Module Left Of Steering C. In Gray Con. Negative
Fuel Pump WHITE/ Red Junction Conn. Below Fuse Box In Driver's Kick Positive
Rear Defogger Yellow (4) Junction Connector At Left Of Steering Column 8 Min.Neg.
VSS White [Except BOSE] Radio, 24 Pin Plug, Or Instr Cluster, 24 Pin Plug AC
Head Lights Yellow/Red At Light Switch, 17 Pin Plug, Pin 13 Negative
Wiper Protection BLACK/ Green At Wiper Switch Open
BackUp Lights RED / Yellow Junction Conn. Below Fuse Box In Driver's Kick Positive
Transponder RX Blue/Organge Or Purple At Transponder Module Data
Transponder TX Yellow/Black Or Gray/Blue At Transponder Module Data
IM/OM Compatibility
- OM-CUT-II (310-908-500) - OM-CUT-3 (310-907-516) - OM-FOT-1 (310-907-580) - 755T2 - 555F(W) - 1101T - CANMAX400 - MAZDA2
- CANMAX400 - MAZDA2 - PKALL - - - - - - - - - - - - - - - - - - - - - - - - - - -
Comments :
Notes: This vehicle is equipped with a transponder that need to be bypassed.
(1) Door locks control module located on the left side of the steering column, 1K ohms to ground will lock and straight to ground will
unlock
(2) You need to send a negative Start pulse to this wire at the same time as the main Starter wire is powered up.
(3) The Disarm pulse also unlock the door.
(4) Indicator will not light up.
Posted By: monty_77
Date Posted: December 10, 2009 at 12:39 AM
check you Private messages
