viper 571xv what?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=118418
Printed Date: May 05, 2026 at 8:50 PM
Topic: viper 571xv what?
Posted By: ladder49vfd
Subject: viper 571xv what?
Date Posted: December 10, 2009 at 7:23 PM
This is an excerpt from the Viper install manual regarding what I am supposed to do with a WHITE/ blue wire from the Viper remote start:
"""""""""""""This input comes from the factory set to 2 activation pulses. This means that it is necessary to have 2 consecutive
ground pulses on the WHITE/ blue wire for the remote start to activate or to deactivate. The same holds true
for the remote control activation when set to a two pulse setting it is necessary to press the button twice
for the remote start to activate or deactivate.
NOTE: When the activation pulse count can be programmed to 1, 2, or 3 pulses when changed
it will affect both activation inputs; the WHITE/ Blue wire and the remote control activation."""""""""""
The only thing it skips telling me is, what the heck I am supposed to attach it to. Can anyone decode this cryptic instruction?
Peace
Posted By: jim hunter
Date Posted: December 10, 2009 at 7:40 PM
your not supposed to hook it to anything. it would be used IF you wanted an alternative device to start vehicle(i.e. factory remote- hooked to lock wire car would start whenever you pushed lock button 2x, or you could wire in a push button for starting the car from inside without the keys or remote) but for standard install it goes to nothing
Date Posted: December 10, 2009 at 7:55 PM
Thanks, you know, I thought that was it, but I have so many darn unused wires on this harness I'm like what the heck? But I get it. Thanks.
Peace
