bypass antenna loop
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=118458
Printed Date: March 31, 2026 at 4:21 AM
Topic: bypass antenna loop
Posted By: Astro4X4
Subject: bypass antenna loop
Date Posted: December 12, 2009 at 3:26 PM
I'm having a retard moment here and need some help. R/S on a '06 Dodge Dakota, using a PKUCG2X transponder bypass. The antenna loop is huge compared to the ignition cylinder so do I take the loop apart so that is wraps tight on the ignition ? Directions also call for 3 or 5 turns of loop and there has to be about 50 strands of copper in it? This is the first install I've had to use an antenna loop on and it's also the first install giving me way to much grieve to get around the OEM immobilizer.
Thanks in advance,
Dave
Posted By: Astro4X4
Date Posted: December 12, 2009 at 3:42 PM
Another question, do I need to use two different keys when programming the PKUCG2X? Instructions don't say so, but I saw a reference in another thread about 2 keys.
Posted By: icearrow6
Date Posted: December 12, 2009 at 3:57 PM
Loop the antenna around the cylinder like you would a rubber band.(I'm not saying that it stretches!! I'm saying in the way you twist to loop)
Try to start it semi tight around the cylinder, and its ok if it ends up a little loose at the end. i haven"t had a problem with it being hard to pickup because of that.
And i think you still need two keys to do the programming. i don't know any other transponder that doesn't require the two key programming.
Posted By: tommy...
Date Posted: December 12, 2009 at 4:05 PM
I saw some bypass mentioned by luongo or pierson about only needing one key with a new bypass...Yes you need two keys...You can temporarily hold the loop in place with some electrical tape...Maybe even for good...! ...The bypass loop already is "wrapped"...The 50 strands you refered to...! You could of always used a universal key bypass...And got another key programmed...One without the keyless built in...Although there is still a loop...!
------------- M.E.C.P & First-Class
Posted By: kgerry
Date Posted: December 12, 2009 at 5:01 PM
the new idata firmware allows you to do a vehicle with only one key.... all the bypass and expresskit units require two keys.....
------------- Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
