2010 mustang
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=118482
Printed Date: May 02, 2026 at 12:36 PM
Topic: 2010 mustang
Posted By: metz35
Subject: 2010 mustang
Date Posted: December 13, 2009 at 11:45 AM
i did this car awhile back for free.99 job for my bosses daughter.. and at the time there was limited information.... so a couple weeks back she brought it back so i could finish door triggers , trunk triggers, and parking lights. well all is good except parking lights, new information reveals that gray is - and PURPLE / white is +, however, they test as such but dont trigger the parking lights on the outside.. ive tried using a relay to boost negative, ive tried isolating from the switch, ive tested for resistance...and i have nothing..ive found the gray behind the switch, and purple white in passenger kick. they test but do not work ...........ANY IDEAS?
Posted By: i am an idiot
Date Posted: December 13, 2009 at 12:10 PM
posted_imageParking LightsGRAY(-)IN HARNESS AT SMART JUNCTION BOX IN PASSENGER KICKPANEL
Posted By: metz35
Date Posted: December 13, 2009 at 2:55 PM
gee thanks for the information i already had.. big help
Posted By: mikvot
Date Posted: December 13, 2009 at 4:15 PM
Yep...don't see that either iaai. Guess he fails to realize, that just because the color of the wire is the same...doesn't mean that it is the same wire he has already tested at the switch, or even provides the same function. Guess he will have to figure it out on his OWN. Now that's a "big help"!
Posted By: chev104275
Date Posted: December 13, 2009 at 4:50 PM
at the SJB there is a gray 13 pin connector pin 6 should be violet white its the park relay output goes to the lights
Posted By: metz35
Date Posted: December 13, 2009 at 5:22 PM
chevy tried it, every wire everyone mentions is there an also test as such. but when either a negative to THE GRAY AT THE KICK OR AT THE SWITCH, or the PURPLE / white + at sjb it doesnt activate the lights but it test as parking lights.... think it has something to do with the auto lights?
Posted By: metz35
Date Posted: December 13, 2009 at 5:27 PM
nope i have no clue at all what im doing.
Posted By: mikvot
Date Posted: December 13, 2009 at 5:40 PM
Never said you didn't know what you were doing....I know, you think you are some kind of god like installer....but come on...park lights on a Ford?.. some one gives you some input and you reply with a smart*** comment. We don't know exactly what info you have, and exactly how you are testing, so we will throw out any info we have. If it's info you already have....say thank you, I already have that info and move on. It's simple...it's called respect.
Date Posted: December 13, 2009 at 5:55 PM
may sound dumb but have you tested the positive parking output of your system   that wire i listed goes directly to the parking lights
Posted By: metz35
Date Posted: December 13, 2009 at 6:00 PM
ya i have tested positive and negative (compustar has both) i tried using relay to up both poitive and negative , isolating both from the switch, and sjb. im outta ideas.
Posted By: metz35
Date Posted: December 13, 2009 at 6:06 PM
respect, then let the MAN i so called disrespected speak for him self..instead of having u defend him. also your posts to me were really respectful..its called hypocrisy.
Date Posted: December 13, 2009 at 6:20 PM
i dont know what else to suggest that wire goes from the parking lamp relay output right to the parking lamps   ive used it with out any issues
Posted By: mikvot
Date Posted: December 13, 2009 at 6:40 PM
I'm not defending anyone...you are on a forum, which I am part of, and obviously have an attitude. I have a simple solution to the problem though. Bring the car to me, and I will do it for you...with, or without tech info.
Posted By: metz35
Date Posted: December 13, 2009 at 7:34 PM
how you gonna do the parking lights though? you still havent posted anything useful to this thread? and i also am part of this forum. which means i can or will have an attitude if i so choose to..and you also can choose to be an ass an be unproductive.. im done with this wizing contest..
Posted By: mikvot
Date Posted: December 13, 2009 at 7:58 PM
Good...you're done. Not a "wizing" contest at all. I posted something useful...I told you I would do the car for you. How much more helpful can you get? Sucks for you though. Most of my dealer work for the last 5 years has been on Ford vehicles. But, just as you choose to have an attitude...I choose not to give you info. Have a great night!
Posted By: metz35
Date Posted: December 13, 2009 at 9:14 PM
Yes I'm done. But apparently you are not. So know who thinks they are the god like installer.
Posted By: howie ll
Date Posted: December 14, 2009 at 2:29 AM
Guys, guys lets stop this anyway with Loneranger an infrequent visitor I'M bad cop or grumpy old man around here!
Trouble is I've spoken to both of you before and I know you BOTH know what you're talking about so let me make another suggestion:
Floor loom going to rear, pick it or them up here, on each or both? do you have to relay isolate them? Surely if you provide 12volts to each wire that will do it?
Posted By: big sexy lac
Date Posted: December 14, 2009 at 9:39 AM
parkinlights (-) gray headlight switch or SJB, black 52 pin plug (B), pin 31
parkinglights (+) PURPLE / white SJB, black 32 pin plug (D), pin 20
let me know if this helps
WELL?
