94 fullsize blazer 791xv reprogramming
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=118551
Printed Date: April 30, 2026 at 8:11 PM
Topic: 94 fullsize blazer 791xv reprogramming
Posted By: gmoney43080
Subject: 94 fullsize blazer 791xv reprogramming
Date Posted: December 15, 2009 at 12:42 PM
I messed my alarm system up trying to add on the trunk option, by tryin to program the remote pressing buttons like I knew what I was doing I hooked the relay up how they said to hook it up and it didn't work so I thought I needed to program my remote for some odd reason (my first remote is the one with the screen). and now I can't remote start my car it tries but it stops too soon to start it and my doors won't lock or unlock, please help me even with my second remote, but on my second remote I can arm and disarm (but still can't unlock or lock it) it but on my first remote I can only arm it, it won't disarm, if the alarm goes off I have to press the arm button again to stop it.       I tried this.    Just re-program the remotes, STEPS- 1) open door 2) Turn ignition on 3) press and release valet switch twice holding on second press, wait for a single chirp from the siren, then press lock button on remote! then press lock button on remote! A long chirp indicates success!        THAT didnt work either, it made all the sounds you said it would make but still wont unlock the doors or hatch or start the truck, it will try for a half of a second and stop i didnt think to check for blown fuse in the box but i checked the fuses associated with the viper because i went off of the wires connected to the door lock relays for power but the locks was still working fine until i started messing with the valet button, and i also accidentally followed the process to program the viper with the computer thing (bitwriter) if that can help you help me in anyway, i was pressing button   I forgot to mention if I start thr truck using the key, if I press the start button two times to take my keys with me the lights will blink but the doors won't unlock and when I turn the ignition of the truck cuts off but t seems like its on (meaning the lights are on and if I try to put the keys back in to start it, it won't as if the anti grind mode is on so I have to press the brake to shut it of and then start it
Date Posted: December 15, 2009 at 1:49 PM
Got it fixed it was a fuse
