Autopage RF-305 wire diagram
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=11864
Printed Date: April 13, 2026 at 12:03 AM
Topic: Autopage RF-305 wire diagram
Posted By: quiksliver808
Subject: Autopage RF-305 wire diagram
Date Posted: April 06, 2003 at 4:07 PM
Does anyone have the wire diagram for the autopage rf-305. I just installed auto doorlocks and now i need to know what wires to hook them up to. Also do I need to reprogram the alarm so that it will lock and unlock when i press the button on the remote.
Thanks posted_image
Posted By: tacoma808
Date Posted: April 09, 2003 at 5:49 PM
I sent you my email via PM.  The install guide pics I scanned for you are too large to post here.  I'll send them via email attachment.
Date Posted: April 09, 2003 at 5:55 PM
from 10nesne1's prior post:
Autopage RF-305 Installation Manual:
Green-----Parking Light Output (10amp) (+)
Red-------12 Volts Main Power (15amp) (+)
Blue-------Siren Output (+)
Black------Main Ground
BLACK/ White-----Starter Interrupt (300 mA [-] output)
Yellow---EXT1 or 2nd Channel (200 mA [-] output)
Gray------Negative Door Pin Trigger Input
Pink-----Added Sensor or Negative Pin Switch Trigger Input
Purple------Positive Door Pin Trigger Input
White--------Ignition Switch Input
Door Lock Input Plug
Light Blue--------Door Unlock (-) or Door Lock (+)
Red--------12 volts Output (+)
Light Green-------Door lock (-) or Door Unlock (+)
