does dei 610t relay have coil diodes?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=118718
Printed Date: May 05, 2026 at 7:43 PM
Topic: does dei 610t relay have coil diodes?
Posted By: smoketest
Subject: does dei 610t relay have coil diodes?
Date Posted: December 21, 2009 at 8:07 PM
1) Do the DEI 610T 30/40A relays have the coil diodes already built-in across the relay coil?  I suspect they do not have a built-in coil diode.
2) In general how can you test (with an ohm meter) to determine if a relay has a built-in diode across the coil? Can get a little tricky if the coil has low impedance. Do the relays with built-in coil diodes always indicate the diode on the relay labels?
3) Why don't the mfg of alarm/remote control units simply protect the their trigger output pins (ie the -200mA active low outputs) with a reversed biased zener diodes to gnd? This way the user wouldn't have to install these coil damper diodes. Than if the kick back voltage got too high,  the the zener in the CM pin would turn on and snub it out.
Posted By: i am an idiot
Date Posted: December 21, 2009 at 8:11 PM
The only way I can think of that you can test to see if there is a diode would be to get a 1/2 amp fuse put it inline with the power wire, and connect the coil backwards.  If it blows the fuse, there is a diode.  If it does not blow the fuse, there is no diode.
Date Posted: December 21, 2009 at 9:46 PM
The fuse method seems crude but it should work.
P.s. I just measured the coil res on a 610T at 87.2ohms in both directions. I also experimented with high & low terminal voltage in ohmic mode on my multimeter to see if I could detect any forward/reverse biased diode conditions. I could not, the coil always measured approx 88ohms. So than I added a diode across the coil and repeated the experiment. I still could not detect the the diode (the one I added) regardless of probe orientation and meter settings. Still measured approx 88ohms in both directions. So it appears that detecting a coil diode with an ohm meter is not possible.
12v/88ohms=136mA, so could use a 0.25A fuse instead of 0.5A and help reduce the stress during the fuse blow test.
Date Posted: December 21, 2009 at 10:07 PM
Yes you can use a smaller fuse.  A 500MA fuse is just easier to find than a 250.
Posted By: oldspark
Date Posted: December 22, 2009 at 12:46 AM
You could add a series resistor of (say) ~47 to 820 Ohms and connect both ways across 12V.
Measure the voltage across the solenoid.
If it is greater than ~0.7V (and the same) in both polarities, there is no diode.
Posted By: howie ll
Date Posted: December 22, 2009 at 3:14 AM
For the cost of a diode, why not play safe and install externally.
Posted By: oldspark
Date Posted: December 22, 2009 at 7:37 AM
Which could be placed at the whatever (alarm etc) outputs....
Of course quality equipment should have such protection...
(Speaking of quality - Ford Aust have just recalled some models after a cruise control took over - the driver could not turn off ignition, change gear, etc. That's what I call a BAD design. People wonder why I don't have any automated controls without overrides.... - eg, ABS, wipers, etc)
Date Posted: December 22, 2009 at 8:42 AM
Bingo... oldspark ! I think your method is 100% correct. Basically create a voltage divider and check to see how the +12v source gets divide up. The forward biased diode should not exceed approx 0.7v across it give the exponential VI profile for a diode. I will test this method tonight but I am sure it will work! Simple concept and better than the fuse because its non-distructive to all elements under test.
Posted By: oldspark
Date Posted: December 22, 2009 at 6:37 PM
smoketest wrote:
...(create) a voltage divider
Dang! That's the tech-word for it! posted_image
Talk about knowing concepts but not (caring about?) the detail!
Maybe next time I'll say "try a voltage divider". (That'll keep anti-verbose experts & the knowing happy, and the others status quo.)
When suggesting resistor values I pondered "what is the current rating of an in-build diode"? I doubt that it would be even 1A??
FYI - I only ever use "raw" relays. If I ever had a diode protected relay, I'd probably try to blow it open or remove it.
And that reminds me....
Posted By: oldspark
Date Posted: December 22, 2009 at 8:06 PM
Dang #2 - I was going to re-reply with a specific "Topic" heading. Alas this forum doesn't have that.....
Anyhow, it was going to be "A Brief about Relays and Circuit Transients" (with optional <Ramble> after Brief).
It was spawned by this thread, my avoidance of relays with inbuilt protection, and something I read somewhere recently - maybe on 12Volt...?
The issue had to do with NOT having a protection diode (or quenching circuit) across a particular relay.
The comment was something like "although that relay may be ok, I don't know about the effect on other relays...." etc.
The simple answer is all the relays (solenoids) will be subjected to the same voltage spikes etc.
The way it was written, it made it sound as if the unprotected relay could inject a spike into another relay and wreck it, or trigger it etc.
No. Even if they are in parallel, they both see the same spike and react the same.
A 200V spike from the 1st relay has that same effect on itself as it does on the 2nd relay etc.
Not that they would be in parallel, but that is probably the worst case.
If they are in series, then the other relays will fight (suppress!) the spike caused by the first.
But other relays are usually in some semi-parallel arrangement with each other (eg, common ground; various solenoid voltage sources).
The general reason for quenching is certainly NOT the protection of other solenoids (inductors), nor other circuits, but noise suppression (EFI/EMC) where the philosophy is quench as close to the source as possible.
IMO it is not for circuit protection as any relay switching circuit should have its own protection.
And any equipment that is intended for vehicle operation should have its own protection for outside of the common 8-16V operational range, and the common 200V or higher spikes expected in a vehicle's environment.
If not for EMI/EMC, relays would be unprotected and a single diode or snubber placed across equipment inputs/outputs are required.
Oh well, what started as a correction to an incorrect "but logical" circuit analysis is now getting TEMPESTuous. (That relates to EMC...) At least is is brief.... I could have gone into detail....
