mobile wifi
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=118811
Printed Date: May 05, 2026 at 6:22 PM
Topic: mobile wifi
Posted By: el ranchero
Subject: mobile wifi
Date Posted: December 25, 2009 at 9:42 PM
i do mobile installations and woulc like to be able to have access to the wide technical help that is in this web site and all the other sites like audiovox,etc but i can only access it by land, is there a mobile wifi device out there or is there a blue thooth thing that i can connect to my lap top via my cell phone, im old school and just getting into the new technology out there, thanks for any advice. peaCE..
rocker
Posted By: tedmond
Date Posted: December 25, 2009 at 9:47 PM
well you can alwasy get a phone with a data package for 3G service. then juse use the browser on the phone and pull up info. I would use the internet stick provided by your ISP, plug that into the laptop and voila, wifi wherever you go.
Ted
Compustar Expert
Posted By: zerepdivad
Date Posted: December 25, 2009 at 9:50 PM
You can get a broadband card from a number of providers. you can use them anywhere, and they hook to your laptop the same way a flash drive would.
A DMM is a beautiful thing.
Date Posted: December 25, 2009 at 9:54 PM
thanks for the help.
rocker
Posted By: howie ll
Date Posted: December 26, 2009 at 3:51 AM
Over here, I'm using a Vodafone (Same company as Verizon) with a 3G dongle attached to my laptop. All of my work is mobile and I either use my laptop and WiFi to their system or their computer. All my paper work, invoices and the tech info for DEI etc is on an 8gig USB flash dongle'
Roll on 4G and nationwide WiFi.
Posted By: tedmond
Date Posted: December 26, 2009 at 6:52 AM
howie, you do mobile? for car dealers etc?
Ted
Compustar Expert
Posted By: howie ll
Date Posted: December 26, 2009 at 7:29 AM
Planning, planning and more planning. Usually work from the trunk of my car, in the winter I use their workshops.
ALWAYS have spare Weller Pyropen with spare bits, also have spare bits for Weller gun, butane cylinder for the Pyropens,carry about 10 reels of insulating tape, Scotch 33 and fabric tape, assortment of Velcro and stickies, all the normal tools, Snap-On 8 x 10mm 12 point ratcheting ring spanner, + multiples in 2.5mm and 3.2 mm, 4mm, 6.5mm 10 and 12, 14 and 17mm (3/32 to 11/16) + 1 normal and 3 stepped cone cuts. Philips 0, 1, 2 and 3, Pozi 1 and 2, T8-T55 (the last few sizes for seat bolts) also some reverse Torx (E series) + Hex head and various security bits. Bosch 10.5, and 18v lithium drill/drivers, always charged. Large selection of radio keys, the blue bojo trim tools, 1 x skewdriver,test leads, DMM, parts box full of tap tight screws, normal, 4,5,6.4 (6mm, 7mm, 8mm and 10mm spanner size) bolts, crimp ring and 6.4 mm lucar (for pin switches) + fuses +WD and lithium spray, pull tool + ground down cabinet (long shaft) screwdriver for grommets. And most important lock-blade pen-knife, great for switches and starting panel extraction, plus the normals, electrical screwdrivers ratchet crimps, regular and no-insulated crimps, Stanley knife, 3 x different strippers, selection of 1 and 3 amp diodes, relays etc. when I go extreme mobile, i.e. by train or plane I have to know EXACTLY what vehicles, take only what I need. Yes I've been caught out, one van was used as a surveillance vehicle and instead of removing the panel via torx, I had to make up something to remove hex bolts, also I've been known to borrow a car to find a local hardware store! In the winter I also carry a power pack. I still manage to keep my back seats clear, although I've long lost the trunk liner around the hood catch (or striker area) it's been used as a work bench too often! I also carry two rechargable LED work lights and there is extra lighting in my car and in the trunk!
Posted By: howie ll
Date Posted: December 26, 2009 at 7:32 AM
I forgot the hand cleaner, 4 litres of water, jump leads, invertor, hydraulic jack, wheelbrace, camera and 10" Infinity free air sub!
Posted By: tedmond
Date Posted: December 26, 2009 at 7:48 AM
ahah well said. i should have asked what DONT you have in your car?!
is the scotch 33 getting any cheaper over in the UK?
Ted
Compustar Expert
Posted By: metz35
Date Posted: December 26, 2009 at 9:39 AM
i use a netbook, monthly service is about 60$ and the laptop is no bigger than a 5x7 picture frame . just a suggestion
Posted By: howie ll
Date Posted: December 26, 2009 at 9:44 AM
A netbook is a great idea but I find the screens are too small. Scotch 33+ still expensive but during the recession all DEI product went up 20% in the UK.
Posted By: metz35
Date Posted: December 26, 2009 at 10:01 AM
tell me about it i paid 75$ for 20 rolls of 33+
Posted By: howie ll
Date Posted: December 26, 2009 at 11:50 AM
Equivalent to $110 for 20 here so shut up metz! Wait till I tell you the price of Pyropens, Juniors and Guns now over here! Solder has doubled in cost in the last year even the older lead cored type. As for lead free, forget it. At my age the damage to my chest/lungs has already been done,also the lead free doesn't seem to flow properly and eats your bits! I mean the iron bits for those of you with dirty minds. Weller bits here around $15 each.
