remote starter bypass module
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=118825
Printed Date: May 05, 2026 at 1:03 PM
Topic: remote starter bypass module
Posted By: jordanmartin
Subject: remote starter bypass module
Date Posted: December 26, 2009 at 3:57 PM
Hey, I have a 1999 Ford Expedition Eddie Bauer Edition. I'm installing the Viper 5901 security/remote start system. The alarm and keyless entry works fine. The remote start works, kinda.
In order to bypass the immobilizer i'm using the xpresskit pkfm xk05 bypass module. The power led is flashing so I know it works. I've tried programming it several times, resetting it and I have checked and re-checked the wiring (with a voltage tester, it works).
If I plug in the module and try to start the car with the key then my theft light flashes and the immobilizer system turns on, the car does not start. If I disconnect the module, I can then start the car with the key. If the key is sitting in the ignition (whether the key is turned on or not) and the module is disconnected then the system can successfully start the car so I know that everything is wired correctly.
With the key in the ignition and the module disconnected, the car can remote start, but as soon as I remove the key the engine dies.
I think that the module is not wired correctly. I've attached the wires from the module to what I think is the harness for the immobilizer; and I know this is the correct harness because if I disconnect the harness the ignition fails (with key turned on or not / module disconnected) when I try to start the car.
I know that this means the bypass module is not wired correctly, but I guess i'm asking for help on how wire it up and program is correctly.
Sincerely,
Jordan
Date Posted: December 26, 2009 at 3:59 PM
I can even get the car into pit mode by starting the car with the key (and the module disconnected) and then plugging in the bypass module. I then press the remote start button and remove the key, the engine will stay on. Brake will shut it down.
Posted By: kreg357
Date Posted: December 26, 2009 at 5:23 PM
Are you using the PKFM or the XK04?  You typed XK05 but I believe you meant XK04.  Either way you want to make sure you flashed the module with the PKFORD firmware.  Your Explorer is a PATS 1 that year so you only need one key to program it.  Your ignition switch connector should be a Type A.  Pin 3 is RX and should be Gray/Orange and you should attach the PKFM Pink wire.  The PKFM green TX wire goes to Pin 4 ( TX ) and should be WHITE/ Light Green at the switch.
Date Posted: December 26, 2009 at 6:25 PM
I bought the unit off ebay. The person I bought it from programmed it before he sent it. The manual from the website says that its compatible with my car.
I attached the green wire to the 4th slot(tx) and the pink wire to the 3rd slot(rx); this configuration makes light on the module flash really fast and then turns solid. my theft light flashes and then turns off after a while.
with the wires setup to be vise-versa, it makes my theft light flash and not go out. The remote start does not function with the key out of the ignition.
Jordan
Date Posted: December 26, 2009 at 6:31 PM
I figured it out. I forgot to connect one of the tiny plugs at the actual PATS module. Thank you for your reply!
Can you help me out with the parking light? I've tried acouple things but they all have a problem.
Jordan
Posted By: kreg357
Date Posted: December 26, 2009 at 6:49 PM
I am not too familiar with the Viper 5901 unit but on your Explorer the parking light wire can be found at the switch itself ( WHITE/ Black ) or in the Drivers Kick panel its Violet/White.  Both are a (+) signal.  If you need to set up the Viper, try starting a new Question with Viper 5901 in the header....  There are a lot of Viper experts on the forum.
Date Posted: December 27, 2009 at 12:20 AM
I could not find the WHITE/ black or violet/white wires. The brown wire controls the parking lights and the dash lights, which whenever the parking lights flash, the interior dash lights flash as well; this is not what I want. I checked every wire on the light control module and every one is connected to the light dimming switch (which according to https://www.toyotatundraforum.com/pdf/Responder%20LE%20Model%205701%20Installation%20Manual.pdf is the correct way to find the parking light wire)
I did hook the parking light output to the hazards in the steering column but whenever the remote start is triggered it thinks the brake is pushed and turns off. (it was also hooked up to turn on all my brake lights, for visibility)
Jordan
Posted By: kreg357
Date Posted: December 27, 2009 at 3:20 PM
I'm sorry, you said Expedition and I gave you explorer.  It is a (+) Brown wire as you said.  Did you try the Head Light Switch itself?  Another place to look for the Parking Light wire (in the Exedition) is in a Black 8 pin connector in the Drivers Kick Panel.  It is also Brown (+).
Posted By: jim hunter
Date Posted: December 27, 2009 at 6:29 PM
the dash lights are going to come on with the parking lights, the switch sends power to both and if i recall there is no isolation point so no matter where you get a parking light feed your instrument cluster wil llight, whats the reason for not wanting that?
Date Posted: December 28, 2009 at 2:21 AM
I ended up hooking it up into the brown wire at the switch.
I also connected the +12v white wire to every connection and came to same conclusion as jim hunters response. Thank you anyway.
I didn't want it just because i'm self-diagnosed ocd and it bugs me (>_<) but i'll get over it. There really is no reason other than it looks unprofessional.
Jordan
