unlock/lock problem after alarm
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=118888
Printed Date: May 05, 2026 at 1:44 PM
Topic: unlock/lock problem after alarm
Posted By: legenux
Subject: unlock/lock problem after alarm
Date Posted: December 28, 2009 at 12:15 PM
Hi all,
I notice my car will unlock very weak when I press unlock from the driver door. This happened after I started to find the unlock / lock wires and test the wires by grounding them to verify when I installed my alarm. Battery is good. Lock seems to work better than unlock. If I keep pressing unlock repeatedly, it moves the locking mechanism back a bit more. Confused on what's the problem.
03 Nissan Murano
Posted By: xtac1080
Date Posted: December 28, 2009 at 12:22 PM
Do all of the doors unlock very weak? What happens when you try to unlock from the passenger door?
Posted By: legenux
Date Posted: December 29, 2009 at 12:10 AM
Same. Lock works , unlock seems to be "lazy" on the remaining doors, when pressed from either driver or passenger. Maybe actuators all dying?
Posted By: KPierson
Date Posted: December 29, 2009 at 12:24 AM
Check the voltage from lock to unlock in both directions.
The Nissan system uses relays integrated in the BCM so it should be pretty easy to figure this out (ie there is no switch wiring to worry about, you only need to worry about the actuator wiring).
How did you connect door locks?  Have you tried disconnecting the door lock wires?  Did you do anything with any of the actuator wires?
Kevin Pierson
Posted By: zerepdivad
Date Posted: December 29, 2009 at 1:58 PM
So how many wires did you randomly ground before you found the right wires?
A DMM is a beautiful thing.
Posted By: legenux
Date Posted: December 29, 2009 at 2:28 PM
Found them on first try - I had directed emailed me the wires and location. Getting to it was painful - all the way inside the door.
Posted By: el ranchero
Date Posted: December 29, 2009 at 6:01 PM
check the doorlock module, i remember that some hondas and nissans had this problem it ended being the factory door lock module chck to see of the module some of them are inside the door panel see if its getting a good ground, this problem arose a lot and the dealerships blamed the alarms alot but it ended with the factory module replaced.
rocker
Posted By: xtac1080
Date Posted: April 21, 2010 at 10:45 PM
Same. Lock works , unlock seems to be "lazy" on the remaining doors, when pressed from either driver or passenger. Maybe actuators all dying?[/QUOTE]
How are you activating these wires? Did you cut them or tap into? Sometimes when you pull apart the copper shield you also pull apart some of the copper, leaving less room for current to travel. Just a thought.
Posted By: t&t tech
Date Posted: April 22, 2010 at 7:06 PM
It's nissan, so i'm assuming negative trigger,  possibilities, the unlock voltage signal is weak from the bcm or because of the less copper for current to travel through as stated above (doubtful of this theory in this instance but............)! Or the Actuators are "dying" ! (which i doubt)
