2006 chrysler pacifica, bypass module?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=118890
Printed Date: May 05, 2026 at 3:10 PM
Topic: 2006 chrysler pacifica, bypass module?
Posted By: chev104275
Subject: 2006 chrysler pacifica, bypass module?
Date Posted: December 28, 2009 at 1:23 PM
what does everyone recomend for a bypass module for this car ?     this will be my first new chrysler
i was looking at the idata link stuff i think it was the ADS-CH
Posted By: tedmond
Date Posted: December 28, 2009 at 4:01 PM
im a Fortin guy. I would recommend the INT-SL, does FAD, locks, triggers, tach, lights, sliding doors, defrost, pk3 bypass and even parkinglights,
take a read if you want. https://ifar.ca/en/products/flash/int-sl%2B/features.html
good luck!
Ted
Compustar Expert
Posted By: mustyk@att.net
Date Posted: December 28, 2009 at 6:53 PM
I'm a  bypasskit/Omega  guy so I use IBU-CH2X  or IBU-CH2 if you don't mind hand wiring the resistors and relays. You can also use PKU-CH2GX. All will work fine as long as you have two original keys to program with.
thetopinstaller
