2001 grand am, viper 5701
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=118904
Printed Date: April 03, 2026 at 9:29 PM
Topic: 2001 grand am, viper 5701
Posted By: vipersport328
Subject: 2001 grand am, viper 5701
Date Posted: December 28, 2009 at 7:10 PM
Im installing a Viper remote start in a 2001 pontiac grand am. Wondering If I hooked up all wires correctly. When I go to start the car the radio and fuel pump turn on but doesn't start. I hooked up an XK01. Here's how I hooked up the 10 pin connector.
Harness Vehicle
Pink Ignition 1- Pink
RED / white-N/A
Orange-Orange
Violet starter car side-Yellow
Green starter key side-Yellow
Red 12V-Red
Pink/White-N/A
Pink/Black-N/A
RED / Black-N/A
Not sure if the other power wires needed to be connected and what there function would be.
Thank You
Pete
Posted By: x1le
Date Posted: December 28, 2009 at 8:29 PM
pink/white must also be connected to your second ign. in that car.
After you've made the connection, put the key the ignition and see if it remote starts. If yes, then remove the key and try again. If it doesn't start the 2nd time, double check your bypass wiring.
-x
Date Posted: December 28, 2009 at 8:54 PM
Thank You will try that sometime this week and let you know the outcome.
Pete
Posted By: dasbogie
Date Posted: December 28, 2009 at 10:22 PM
RED / black needs to see constant 12 volts and if you use 2nd ignition(pink/white), the RED / white needs to see constant 12 volts
Date Posted: December 29, 2009 at 7:49 AM
Do I need to hook up any of the remote start output   Relay out of the 5 pin connector.
Pete
Posted By: x1le
Date Posted: December 29, 2009 at 6:48 PM
the status output (blue) should be hooked up to the bypass mod.
Date Posted: December 30, 2009 at 8:04 AM
Thank you Hooked up those wires on the Remote start and the car started everything is working thanks again.
Pete
