viper 571xv problem
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=118972
Printed Date: April 02, 2026 at 5:44 AM
Topic: viper 571xv problem
Posted By: locosol96
Subject: viper 571xv problem
Date Posted: December 30, 2009 at 11:17 PM
Hello All-- Have a Viper 571XV installed on a '98 CR-V. Was working great. Then, my wife comes home and says that it's "not working". The remote has fresh batteries and all, but no button has any effect. No lock/unlock, remote start, or remote hatch release. I dug out the old factory remote and that still works. But, she really wants her remote start back. Does anyone have any ideas as to what/where I should check? Thanks in advance!
Posted By: smokeman1
Date Posted: December 31, 2009 at 10:47 AM
Have you tried to reprogram the remote to the "Brain"? If you have the installer guide, it is on page 27. Transmitter/receiver learn routine. Rich
Date Posted: December 31, 2009 at 1:29 PM
Thanks Rich. I had not tried that. I just finished replacing the shocks and installing a JVC KW-AVX820 in my Expedition. Now I can get the wife's car in and check it out. I'll let you know if that does it! -Scott
Date Posted: December 31, 2009 at 8:00 PM
Nope, no-go. Had to take off the lower half of the driver panel to even find the program button. The guy who intsalled it hid the button and the LED waaayyyy up in the dash....Anyways, followed the instructions, and nothing happened. When I tried to enter program mode, the horn did not chirp and the LED did not light up. It's almost as if the car and the remotes think the alarm isn't there. Anybody have any ideas? Could the brain have died? This thing is only about 1.5 years old.....
Posted By: t&t tech
Date Posted: December 31, 2009 at 8:16 PM
Have you checked the fuse at the power wire of the alarm?
Date Posted: December 31, 2009 at 8:20 PM
Sorry, forgot to mention- I did check all of the inline fuses that I could find leading to the unit. All were fine.
Date Posted: December 31, 2009 at 8:26 PM
Do you have the companion remote or a second 2-way remote to try? Just thinking could be the remote. Rich
Posted By: t&t tech
Date Posted: December 31, 2009 at 8:27 PM
Switch the ignition on the back off and depress the valet switch once! And let me know if the led illuminates constantly! That unit has no door pin input, and i can't remember trying to manually program it, dei units tend to want to "see" the door open to access programming, i wonder! I'll have to check that when i get to work! Do you have the programming manual by chance? -------------
Date Posted: December 31, 2009 at 8:43 PM
Thanks for all the replies folks! I have the owner's manual and the install manual. I have tried both remotes. Nothing happens. I just ran out to the garage and tried it. The first time, the LED blinked once and nothing happened. Tried it again. The LED came on steady, and the "lock/unlock" light on the remote blinked 3 times. Also, when the key is turned to the "On" position, the doors still lock automatically and then unlock automatically when the ingnition is turned off.
Date Posted: December 31, 2009 at 9:06 PM
It seems that the unit is getting power. Have you tried the shutdown diagnostics on page 36 of the install guide? Or maybe delete all remotes in the transmitter/receiver routine menu and then try to auto learn the remotes again.
Posted By: i am an idiot
Date Posted: December 31, 2009 at 9:37 PM
Have you used a meter to verify that there is power on the main power wire of the unit?
Date Posted: December 31, 2009 at 11:09 PM
“Have you tried the shutdown diagnostics on page 36 of the install guide?”” “Or maybe delete all remotes in the transmitter/receiver routine menu and then try to auto learn the remotes again.” --No, have not tried. Will try tomorrow. “Have you used a meter to verify that there is power on the main power wire of the unit?” --No, but would the LED and other functions be working if there was no power on the main power wire?
Date Posted: December 31, 2009 at 11:24 PM
I didn't catch the part where you said the LEDs were on. I really think you need to check it, an LED will light up brightly with as little as 2 volts across it. It may not be getting good power and still be albe to light them up.
Posted By: t&t tech
Date Posted: January 01, 2010 at 8:25 AM
If the ignition locks are working then it says the unit is powered and seeing ingnition as well! Now what does the manual say as reagards the programming, it will be under transceiver learn routine in the manual! List the directions EXACTLY as the manual has them and i will help you from there!
Date Posted: January 01, 2010 at 9:53 AM
1) Yes, the LED works, but only with the ignition OFF. It will stay on steadily once the program button is pressed. The "lock/unlock" confirmation light on the remote blinks rapidly three times. 2) I have already tried the "learn" routine. I cannot get the alarm into the program mode. When I follow the instructions in the manual, nothing happens. No horn chirp, no LED lighting up. 3) I have tried both remotes. Neither one works. 4) I have not tried the shutdown diagnostics. I will try that next.
Date Posted: January 01, 2010 at 2:29 PM
OK, did the shutdown diagnostics. LED blinked 6 times (indicating a +/- shutdown). I turned the car back on and off again, and now everything is working fine. Weird.....Thanks for the help everyone!!
