1999 golf tdi remote start
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=119092
Printed Date: February 16, 2026 at 9:55 AM
Topic: 1999 golf tdi remote start
Posted By: jgtech
Subject: 1999 golf tdi remote start
Date Posted: January 04, 2010 at 3:16 PM
Does anyone know what wire I would connect a remote start glow plug sensor wire to on a 1999 VW Golf TDI (Diesel)? Can't find much in wire diagrams for the TDI.
Jon
Posted By: jgtech
Date Posted: January 04, 2010 at 3:19 PM
1999 New VW Golf TDI
Mars11 Remote Start installation
Jon
Posted By: 91stt
Date Posted: January 04, 2010 at 4:15 PM
Glow Plug: VIOLET/WHITE-At Glow Plug Relay At Relay Panel Under Left Side Of Dash
Posted By: jgtech
Date Posted: January 06, 2010 at 12:19 PM
Thanks, I hope to tackle this, this weekend. I am also getting mixed info on the tach wire colors. Do you also know what I'd look for here? Any other wiring remote start wiring suggestions would be helpful. I have printed off the two wiring reference sheets I found on this site, but they seem to conflict in some areas.
Jon
Posted By: jgtech
Date Posted: January 27, 2010 at 6:13 PM
I got the remote start to work, however intermittently it will set off the alarm (horn) if locked when starting. I tried attaching the - pulse wire from the remote start with a relay connecting the two ends of the alarm wire under the dash, in the Comfort Control module. This didn't help. If I connect to the unlock wire in the drivers door, I don't know how I would lock it after the car is started? I wouldn't want it unlocked during the run time? Any Ideas?
Jon
Posted By: tedmond
Date Posted: January 27, 2010 at 7:26 PM
make sure you have the factory alarm disarm wire hooked up. if you dont, set the unit to UNLOCK-START-RELOCK.
Ted
Compustar Expert
