2008 subaru legacy rs
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=119267
Printed Date: April 22, 2026 at 7:22 PM
Topic: 2008 subaru legacy rs
Posted By: hondaclx2k1
Subject: 2008 subaru legacy rs
Date Posted: January 11, 2010 at 9:13 PM
I was wondering if anyone had wiring information for a 2008 Subaru Legacy remote start. Thanks
Posted By: mikvot
Date Posted: January 11, 2010 at 10:15 PM
| Remote Start | | | | | | | | | | WIRE | | COLOR | | POLARITY | | LOCATION | | | Battery | | WHITE | | (+) | | IGNITION SWITCH HARNESS | | | Ignition 1 | | GREEN | | (+) | | IGNITION SWITCH HARNESS | | | Ignition 2 | | BLUE | | (+) | | IGNITION SWITCH HARNESS | | | Accessory 1 | | YELLOW | | (+) | | IGNITION SWITCH HARNESS | | | Starter 1 | | WHITE/ BLACK | | (+) | | IGNITION SWITCH HARNESS | | | Key Sense | | BLACK/ WHITE | | (+) | | IGNITION SWITCH HARNESS | | | Tachometer | | RED / WHITE | | (AC) | | INSTRUMENT PANEL | | | Speed Sense | | GREEN/ BLACK | | (AC) | | ABS CONTROL UNIT | | | | | ALSO AT INSTRUMENT PANEL | | | Parking Lights | | ORANGE | | (+) | | PARKING LIGHT SWITCH | | | Low Crr. Pk Lights | | BLACK/ WHITE | | (-) | | LIGHTING SWITCH | | | Brake Lights | | BROWN / WHITE | | (+) | | SWITCH ABOVE BRAKE PEDAL | | | Reverse Lights | | BROWN / YELLOW | | (+) | | HARNESS IN PASSENGER KICKPANEL | | | Horn | | BROWN | | (-) | | HARNESS IN STEERING COLUMN | | | | | ALSO RED / WHITE AT BODY INTEGRATED UNIT | | | Rear Defrost | | VIOLET/GREEN |
Date Posted: January 12, 2010 at 9:05 AM
