2004 hyundai elantra remote programming
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=119365
Printed Date: May 16, 2026 at 12:22 PM
Topic: 2004 hyundai elantra remote programming
Posted By: redz250fz
Subject: 2004 hyundai elantra remote programming
Date Posted: January 15, 2010 at 12:08 PM
i replaced the remote on my remoter starter for my 2004 elantra  and im having trouble programming it... i found the hoodpin switch (i think)  and i pressed it and nothing happend  can anyone help? i wass also reading a post on here from a guy a couple years ago and he was saying that you can ground it out with a grey wire or something like that..?
Mr. Yorke
Posted By: kr tony
Date Posted: January 15, 2010 at 1:52 PM
What system???????
-Tony
Date Posted: January 15, 2010 at 5:31 PM
Its a Prostart 2000' two way remote.... the system was installed app. 4 years ago by Audio Heaven and everything worked as it should but last month my daughter dropped the remote for it and it broke...so i just got the new remote bought it from canadian tire, im trying to program it it tells me to Flash the hood switch and before 20 sec is up turn the key to the on position and then the off position,  then hold the lock button  until the lights on the car flash 5 times. problem is when i "flash the hood switch" nothing happenes maybe im doing it worong
Mr. Yorke
Posted By: t&t tech
Date Posted: January 15, 2010 at 5:38 PM
Four years ago! Have you verified the hood switch stil functional?
Date Posted: January 15, 2010 at 8:13 PM
no how do i test it?
and how do i "flash hood pin switch" just push it in?
Mr. Yorke
Posted By: tedmond
Date Posted: January 16, 2010 at 5:59 PM
push down on the hood pin, and look at your parking lights. if they flash then the hood pin is still good, if it doesnt, remove the female plug to the hood pin.
Cut the end off and tap it to ground. if the unit clicks and the lights go on, the hood pin was faulty.
Ted
Compustar Expert
