02’ toyota tacoma
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=11955
Printed Date: April 18, 2026 at 6:35 AM
Topic: 02’ toyota tacoma
Posted By: extreemlylow
Subject: 02’ toyota tacoma
Date Posted: April 08, 2003 at 2:15 PM
need diagram for an alarm install remote start
Posted By: draasch
Date Posted: April 08, 2003 at 9:40 PM
Constant 12 volts WHITE/ RED AND WHITE IGNITION SWITCH HARNESS
Ignition 12 volts BLACK/ RED IGNITION SWITCH HARNESS
Starter BLACK IGNITION SWITCH HARNESS
Dome Light BLACK/ WHITE (-) 12 PIN CONN ON BACK OF FUSE BOX *
Trunk Pin Switch N/A
Parking Lamp GREEN (+) REAR BODY HARNESS, LOWER DRIVER KICK
Power Lock BLACK/ BLUE 12 PIN CONNECTOR IN #209
Power Unlock RED / YELLOW DRIVER KICK PANEL **
* Also Found As BLACK/ WHITE (-) In 3 Pin Conn. High In Dr Kick Panel. * Fuse Box Located Behind Driver Dash
Tach Signal GREEN/ BLACK AT IGNITER OR DASH TACHOMETER *
Ignition #2 BLACK / YELLOW IGNITION SWITCH HARNESS **
Ignition #3 N/A
Accessory BLUE/RED IGNITION SWITCH HARNESS
Neutral Safety NOT GROUNDING TYPE - OEM SWITCH OPENS STARTER CIRCUIT
Brake Light GREEN / WHITE (+) AT SWITCH ABOVE BRAKE PEDEL (DKP)
Reverse Light RED / BLACK (+) AT SWITCH ON TRANSMISSION (DKP)
Rear Window Defrost N/A
* 2WD 4 Cylinder Engine and 6 Cylinder Engine Tach Wire Is Located At Igniter On Passenger Side Of Engine. 4WD 4 Cylinder Engine Tach Wire Is Located At Engine Control Module Located Behind Passenger Dash. On All Models, Tach Wire Can Also Be Found In 26 Pin Gray Connector Behind Passenger Dash. ** Key Warning Wire (LT GRN/RED At Stering Column) MUST See Ground In Order To Remote Start. Suggest Use Negative Ignition Output From Unit
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
